New here not to Oldsmobiles
Old Jan 16, 2013 | 06:06 AM
okolds68's Avatar
Heya,
I am glad to have found this place for fellow Oldsmobile gear heads .
I had a 68 Cutlass S for 12 years then got forced to sell it. I am a few weeks from getting another 68 and will be doing a full spread of before pictures with works in progress.
I will be doing the bench to bucket and center console swap out as well.
Well short and sweet hello
Moose
Old Jan 16, 2013 | 12:40 PM
okolds68's Avatar
The car is a 68 cutlass s post. Bench seat and auto on the tree. 12 bolt one wheel wonder.
Motor in it at this time is a 65. 425 I didn't check the carb so not sure if its 2 or 4 barrel the owner has a 68 350 motor to go with the car as well.
Can any one decipher this for me it's the body tag info. Top to bottom and left to right:
04D
ST 68-33677 LAN361194 BODY
TR 950 K-2 PAINT
I will try and find the build sheet once I get the car. I know it's generally between frame and gas tank.
Old Jan 16, 2013 | 01:40 PM
allyolds68's Avatar
Welcome,
Originally Posted by okolds68
04D
TR 950 K-2 PAINT
Built 4th week of April 68
Lansing Plant
Black bench seat
Ocean Turquoise with a Black vinyl top
You won't find a build sheet under the tank or anywhere in the car. You may find a Fisher Body card under the back seat
Old Jan 16, 2013 | 06:21 PM
okolds68's Avatar
Welcome,
Lansing Plant
Black bench seat
I found the build sheet on my other 68 between the tank and trunk, sadly this one doesn't have the back seat.
Thank you for the information, could you also do the VIN if I provide you it?
I checked the door jams for information on tire size and such and the one on the drivers side is almost completely faded out to where you can't see a thing :/
Old Jan 16, 2013 | 06:33 PM
OLD SKL 69's Avatar
GM Enthusiast
Welcome to CO! Look forward to seeing the pics of your ride.
Old Jan 16, 2013 | 06:38 PM
okolds68's Avatar
Thank you and once I get the car I will take a ton of pictures and post them.
Old Jan 16, 2013 | 07:08 PM
allyolds68's Avatar
The VIN won't really tell you anything more. The car won't have a build sheet because its a Lansing car. The other BOP plants were more likely to leave paperwork in the car. Lansing built cars did not.
Old Jan 16, 2013 | 07:09 PM
okolds68's Avatar
Well dang.. I will still look though Maybe I'll get lucky!
JWMIII47
Dec 21, 2014 10:12 AM
psycho
May 3, 2012 04:53 AM
bkeese
Oct 29, 2010 06:27 AM
OldGuy
Nov 26, 2009 01:42 PM
oldsmoenewbie
Oct 29, 2006 07:19 PM
