New guy looking at a 68 Cutlass, need opinion
Hello all,
I'm Dave. I am restoring a '66 Impala, but am now eyeing a 68 Cutlass. The car seems to be all in very good condition, even the original sheetmetal, EXCEPT the driver's side cowl.
As you can see from the photos below it was damaged at some point in it's life. It does not appear to have affected the rest of the car, but I would like to replace it. So my questions are:
1. Can this be easily cut out and replaced without affecting the integrity of the car? I can weld, so that isn't an issue.
2. Is there easy access to getting a replacement from a donor car? Would anyone have access to one or know where I could get one?
Your opinions would help a lot in my decision to buy.
Also what are some things to look for when checking out these cars (rust, weak frame points, hard to find parts)?
Thanks !!
![](http://i717.photobucket.com/albums/ww177/c-towndave/68%20Cutlass/Dmgcowl.jpg)
![](http://i717.photobucket.com/albums/ww177/c-towndave/68%20Cutlass/Dmgcowl3.jpg)
Thanks !!
![](http://i717.photobucket.com/albums/ww177/c-towndave/68%20Cutlass/Dmgcowl2.jpg)
Thanks !!
#2 - These cars are all over the place so I don't believe parts would be an issue! Acccess is always an issue, just don't set yourself up for a fire!
Good luck!
I am by no means a body expert. Most of the damage would be covered by the fender. As for the top part I would say you could patch in a piece from a donor car. You need to find someone with a parts car. As all GM converts are prone to frame rot check the boxed frame for any holes or flaking inside.
oldsrocket88
April 20th, 2015 10:13 AM
66olds98conv
Ninety-Eight
August 25th, 2013 04:04 PM
