New guy looking at a 68 Cutlass, need opinion
Old Oct 8, 2011 | 11:56 AM
c-towndave's Avatar
Hello all,
I'm Dave. I am restoring a '66 Impala, but am now eyeing a 68 Cutlass. The car seems to be all in very good condition, even the original sheetmetal, EXCEPT the driver's side cowl.
As you can see from the photos below it was damaged at some point in it's life. It does not appear to have affected the rest of the car, but I would like to replace it. So my questions are:
1. Can this be easily cut out and replaced without affecting the integrity of the car? I can weld, so that isn't an issue.
2. Is there easy access to getting a replacement from a donor car? Would anyone have access to one or know where I could get one?
Your opinions would help a lot in my decision to buy.
Also what are some things to look for when checking out these cars (rust, weak frame points, hard to find parts)?
Thanks !!
Old Oct 10, 2011 | 05:59 AM
c-towndave's Avatar
Anyone??
Old Oct 10, 2011 | 06:07 AM
Thanks !!
#1 - Easily, no! It can be done, however, me personnally, I would repair the dent as best I could since it is covered by the fender!
#2 - These cars are all over the place so I don't believe parts would be an issue! Acccess is always an issue, just don't set yourself up for a fire!
Good luck!
Oldsmaniac's Avatar
I am by no means a body expert. Most of the damage would be covered by the fender. As for the top part I would say you could patch in a piece from a donor car. You need to find someone with a parts car. As all GM converts are prone to frame rot check the boxed frame for any holes or flaking inside.
Old Oct 10, 2011 | 01:34 PM
c-towndave's Avatar
Thanks guys. Going to check it out Saturday. If all goes well, I'll be in the club.
Dave
oldsrocket88
Apr 20, 2015 10:13 AM
66olds98conv
Ninety-Eight
Aug 25, 2013 04:04 PM
MY71CUTLASS
Feb 13, 2012 05:40 PM
1980gutlass
Nov 18, 2011 06:28 PM
ddusty1
Drivetrain/Differentials
May 20, 2008 04:12 PM
