need help (info)
Old Oct 30, 2012 | 07:02 AM
wizard's Avatar
need help (info)
I have just joined this group and need some info on my olds. I have a 1984 cutlass supreme , brougham. The wiper, cruise control, washer ,unit has a broken washer /wiper assembly . Will I need to buy a whole new assembly , or is there a better solution, like a used unit from another car, like maybe a buick of similar age ??
thanks for any help.turn signals work just fine !!
Old Oct 30, 2012 | 01:50 PM
If you are talking about the multi-function lever on the steering column (as opposed to the washer/wiper motor on the firewall) then get Dorman Products P/N 49284, available at most auto parts stores. You will need to pull the steering wheel and turn signal switch to fish the wire through the column. Hint: Tie a string to the old wire before you pull it out to simplify this process.
http://www.dormanproducts.com/p-5081-49284.aspx
Old Oct 30, 2012 | 02:08 PM
wizard's Avatar
need help
Joe : Thanks so much for your reply. this must be my lucky day. I'll let you know as soon as I can get it done . !!
have a good day .
wizard
Old Nov 1, 2012 | 05:41 AM
wizard's Avatar
have a good day .
wizard
Old Nov 1, 2012 | 05:44 AM
wizard's Avatar
Joe : I found out that I can get just the "washer " part of that assembly so
I don't have to buy the whole thing. got the part for about ten dollars
Thanks again .
wizard
sx455raidercelticfan
Aug 1, 2010 08:03 PM
viper771
May 31, 2010 12:40 PM
pontchief
20
May 8, 2007 05:06 PM
frdmftr
15
Mar 7, 2007 07:48 AM
pontchief
Ninety-Eight
Oct 21, 2006 02:56 PM
