Hey guys and gals
Old Jun 28, 2022 | 05:55 PM
7deuceCutty's Avatar
Hey guys and gals
It's official I'm an oldsmobile owner just bought a 72 cutlass convertible my first classic always wanted one finally saved up enough and came across a decent deal took me years and I finally did it. It's in pieces, doesn't start and its in rough shape. I decoded the vin and it's a 455 according to the vin but I haven't verified the block .
vin 3j67u2m
Anyone have advice on my new journey with my car?
I want to keep it original 455 if it's numbers matching but from my brief research 455s are expensive to build and not alot of people have expertise in building an olds. I'm not mechanically knowledgeable I would say a novice, I can change sparks plugs basic tune ups but never rebuilt an engine. I'm located in socal tried calling Bernard mondello I hear he's good with these engines but no answer.
Should I stroke the 455 or ls swap?
Gas is expensive right now but it'll be a weekend crusier.
Old Jun 28, 2022 | 07:39 PM
Welcome to the site, post some pictures of your project. The best way to eat an elephant is one bite at a time. Read, ask questions, make a plan for each project to get the car completed.
Old Jun 28, 2022 | 07:58 PM
Old Jun 28, 2022 | 08:12 PM
tnswt's Avatar
'70 4-Speed W Machine
It sounds like you are car proud! Good luck with your project and hope you are on the road soon.
Old Jun 28, 2022 | 08:44 PM
More so grateful and appreciative I used to just fantasize and day dream about driving a cutlass convertible for so long to finally own one is like a good dream come true.
Old Jun 28, 2022 | 09:28 PM
No need to stroke a 455, and ls swapping is sacreligious . A basic rebuild is equivalent to any other engine.
Old Jun 29, 2022 | 03:35 AM
Welcome, looks like a ambitus project but definitely do-able.
Old Jun 29, 2022 | 04:56 AM
Welcome, definitely a cool Olds! Ask questions and we'll help you with your project.
Old Jun 29, 2022 | 07:30 AM
tkcutlass's Avatar
Good luck with your project, looks better than what I started with.
Old Jun 29, 2022 | 07:57 AM
Phoenix8990's Avatar
Congratulations, you are about to embark on the journey of a lifetime! It may look rough but it's not much different than any other car that needs paint and an interior , suspension work etc. They often just look better but need as much work. First thing is to buy a Chassis Service Manual or CSM it will answer many question you have while working on it. Buy and original copy not a reprint or cd there garbage. Contact HairyOlds on this site for one. Take your time and do it right one thing at a time.
Steve
Old Jun 29, 2022 | 08:13 AM
I want more power everyone I spoke to said the 455 has a bunch of torque so should I keep it factory rebuild or bore it over some
Old Jun 29, 2022 | 12:24 PM
70W-32's Avatar
A U code convertible is a fairly rare car, if you LS swap it, you void the reason for being a collector car.
You will have to get your block checked by an engine machinist to determine whether it needs an overbore. If the cylinders arent worn or tapered, keep it standard,
if not, do the minimum overbore to make it right for rebuilding.
Always remember, a mild 455 will easily make 400hp and 500lb/ft of torque.
A 5.3 LS wont come close unless you add a power adder.
If you step up to a 6.2 or bigger LS, the cost goes up exponentially.
Take your time, build that 455, repair the cars body and interior. And have a cool car thats going up in value.
Good luck
Old Jun 29, 2022 | 02:59 PM
tnswt's Avatar
^^^Now that makes sense.^^^
Old Jun 29, 2022 | 07:43 PM
Tj Pal's Avatar
Welcome! I hope you keep it all Olds, however your money, your choice.
Old Jun 29, 2022 | 08:47 PM
Good luck
I didn't know U convertibles we're rare I thought they were a dime a dozen. I thought only the 442 was rare. If I stroke the 455 will that decrease the value of the vehicle? I'm keeping it original if the motor is salvageable I just want to do burn outs and a little spirited driving on occasion. Hence wanting it to have a little more performance.
Old Jun 29, 2022 | 08:50 PM
I don’t think you realize the burnout potential of a stock stroke 455 that has 500+ lb-ft of torque. There is no need to stroke it unless you are building a race car.
Old Jun 29, 2022 | 09:19 PM
OLDSter Ralph's Avatar
This makes perfect sense. A 455 does have gobs of torque.
What do you drive daily ? You really have no idea how much power a 455 has.
X 2
Old Jun 29, 2022 | 10:01 PM
I daily a Chevy 5.7 vortec it gets up and go , cant imagine what 500 ft lbs of torque feels like.
Old Jun 30, 2022 | 07:14 AM
70W-32's Avatar
Imagine your truck roasting the tires all the way across an intersection, and then barking the tires into 2nd. Thats 455 power
Old Jul 4, 2022 | 03:30 PM
So here's some more pics of the engine
Old Jul 4, 2022 | 03:43 PM
Ga heads are these bad?
Old Jul 4, 2022 | 06:31 PM
Tj Pal's Avatar
That motor has plenty of street cruising power. When you start modifying you start to lose drivability. Maybe go to a 323 or 342 posi reared. That should give you a nice seat of the pants feel but no loss of drivability.
Old Jul 5, 2022 | 08:11 AM
Have you tried to start the engine yet?
Old Jul 5, 2022 | 01:14 PM
No, those are good and can be made even better by installing larger valves (I'm assuming yours have small valves from the factory). They are the correct heads for a 1972 455 engine.
kw502bbc
Dec 18, 2020 07:27 PM
Koda
Apr 14, 2020 11:01 AM
EngineErnie
Sep 19, 2016 04:44 PM
1972 X code 442
Hurst/Olds
Oct 1, 2010 08:57 AM
Kwish
Sep 29, 2009 09:55 PM
