Help??!
Help??!
Hi all im new just got my first 1976 cutlass supreme and im having a little problem with the charging system...At idle my gen light is off but when i start driving and i press the gas pedal the Gen light starts to come on and the more i go down on the gas the brighter the light is!! Any ideas?? i have an after market power master alternator and a brand new battery..
I was going to tell you to check your alternator and voltage regulator but I bet that new alternator has a built in regulator. It still might be a good idea to double check it. Welcome to CO.
Ya i dont get it i ended up buying a new battery and installing it and on my way to work the battery ended up dying i lost my blinkers and etc. the thing i dont get is my Gen light wasnt on the whole way up it started up fine this mourning i took a screw driver and touched the back of the Alt and it was a strong pull so i kno the Alt is workin its not charging the battery maybe a bad ground?? I pulled a mutimeter the other day and the alt was sending out around 13.58 volts I dont kno what else to check
ToronadoGuyDenver
Brakes/Hydraulic Systems
Mar 18, 2007 02:52 AM
