Help??!
Old Aug 30, 2011 | 09:35 PM
Oldsrocket12's Avatar
Help??!
Hi all im new just got my first 1976 cutlass supreme and im having a little problem with the charging system...At idle my gen light is off but when i start driving and i press the gas pedal the Gen light starts to come on and the more i go down on the gas the brighter the light is!! Any ideas?? i have an after market power master alternator and a brand new battery..
Old Aug 31, 2011 | 04:50 AM
Oldsguy's Avatar
Past Administrator
I was going to tell you to check your alternator and voltage regulator but I bet that new alternator has a built in regulator. It still might be a good idea to double check it. Welcome to CO.
Old Aug 31, 2011 | 05:32 AM
Ya i dont get it i ended up buying a new battery and installing it and on my way to work the battery ended up dying i lost my blinkers and etc. the thing i dont get is my Gen light wasnt on the whole way up it started up fine this mourning i took a screw driver and touched the back of the Alt and it was a strong pull so i kno the Alt is workin its not charging the battery maybe a bad ground?? I pulled a mutimeter the other day and the alt was sending out around 13.58 volts I dont kno what else to check
Old Aug 31, 2011 | 05:48 AM
Also would it be possible to run a wire from the back of the alternator striaght to the positive ternimal on the battery for a quick fix just to get home??
Old Aug 31, 2011 | 06:36 AM
Sounds like your alternator belt is loose or slipping. As RPMs increase, centrifugal force causes the belt to grow and slip. Try tightening the belt or checking for a glazed pulley.
nolabigdawg
Nov 16, 2014 06:45 PM
MJAKS462
Apr 15, 2010 02:34 PM
silverriff
Mar 24, 2010 06:36 PM
martine
Jan 22, 2009 01:13 PM
ToronadoGuyDenver
Brakes/Hydraulic Systems
Mar 18, 2007 02:52 AM
