Hello everyone My name Is Kevn, I need advise...
Old Jun 7, 2015 | 03:24 PM
AceHole's Avatar
I have just purchased and new half build project and as I have been involved in many VW projects I want to get into a real American project....
I have purchased a Rat Rod and the as it is made up of many many different parts the eng. and trans are an Olds.
the eng. is a 371 and it is attached to what I think is the orig. trans, I was told it was a Hydromantic 4 speed. I posted questions in the transmission section.
Old Jun 7, 2015 | 03:53 PM
Welcome to the site. Looks like a fun project. I edited this post since you posted a duplicate transmission thread. Hopefully someone can give you some direction on how to get it hooked up and running.
Old Jun 8, 2015 | 07:21 PM
AceHole's Avatar
other trans to use???
any idea on any other trans to use that will bolt on to this motor ??
Old Jun 8, 2015 | 07:52 PM
Not without great expense. Lets see if the guys can help you out in the transmission section.
Old Jun 8, 2015 | 09:44 PM
Tedd Thompson's Avatar
Welcome, I couldn't find your post in the transmission section but with out looking or seeing a picture of your transmission I believe you have a 4 speed Jetaway ( not to be confused with the 2 speed Jetaway which will not fit your engine) It is a hydra-matic and not a bad transmission. One other transmission that will fit is a Old's slant pan Hydra-matic which is much like what you have except much stronger. All others will require a adapter, but why do you need another transmission is that one not working or not rebuild able?...Tedd
Old Jun 8, 2015 | 11:29 PM
AceHole's Avatar
here is a photo
Don't need a new one just seeing what options I have I would like to use this trans I was told the motor and trans have less then 70K miles on them I just need a shifter for this one and I was told it might not have a Park ???? I don't know how the two levers on the side work seems like the one oun the far out side is the R D 123 But I have no Idea what the othere one does or where the R is forward or backword
thanks for the help here are some photos
Old Jun 9, 2015 | 04:35 AM
Here is his post under transmissions.
https://classicoldsmobile.com/forums...lds-371-a.html
tomh2513
Aug 23, 2014 09:57 AM
1980gutlass
Jul 2, 2011 12:01 PM
Ne_stang
Feb 5, 2009 06:14 PM
marinus_
Jun 15, 2008 01:41 PM
Indeed
Nov 11, 2007 07:49 AM
