Gas pedal removal?
The place where you should introduce yourself. Do not ask technical questions here, use the site forum sections.
Gas pedal removal?
Jun 4, 2013 | 06:08 PM
R8der4life
May 2013
Gas pedal removal?
I have a 1964 jetstar88 and am trying to install new carpet. Is there a trick to remove the gas pedal from the floor board? Please help.
R8der4life
Find More Posts by R8der4life
Jun 4, 2013 | 06:51 PM
Oldsmaniac
Oct 2005
NJ
You pry it at the bottom. There are 2 ball headed bolts. The gas pedal is pressed onto the *****. Some WD 40 helps.
Oldsmaniac
Find More Posts by Oldsmaniac
gas pedal ball studs ('65 cutlass)
slowolds
02:31 AM
Lights get brighter and dimmer with gas pedal push
Gaz Hog
04:13 AM
Need Information - Gas Pedal Retainer Bushing
My442
04:24 AM
NOS gas pedal, big cars
jensenracing77
05:30 AM
HELP! Gas pedal removal
64starfire
07:43 AM
flexplate problem
05:01 PM
