Blower Motor (and wheel)
Old Dec 23, 2013 | 01:36 PM
OldManTucker's Avatar
(BTW this site is amazing. If it didn't exist I don't know how I would be doing what I'm doing. I am learning as I go...everyday is a winner!)
I am replacing the blower motor, can anyone recommend a good brand? Also, would the new motor accept the original fan wheel? The old fan wheel looks perfect and it seems to be a shame to just toss it.
Old Dec 23, 2013 | 01:53 PM
don71's Avatar
same but different
We might need to know what model are you working on?
In my experience, the new motor should accept the old wheel. I say that, because every motor I've replaced didn't come with a new wheel. Brands, I don't know, just what ever the parts store has.
Old Dec 23, 2013 | 05:25 PM
I'm working on a 1980 Cutlass Supreme, V6 with a lot a pep surprisingly.
It sounds like any new motor will work. Thanks for your thoughts.
Old Dec 23, 2013 | 07:13 PM
The fan wheel is held on with a spring washer, and it will come off but likely you'll break the washer in the process. Most new fan motors don't come with the wheel impeller, so save the old impeller and just install it on the new motor with a new spring washer. Easy fix. I assume your car has AC?
Rockauto has them with impeller for anywhere from 38 - 60 bucks.
O'Reilly's
has them with impeller for 46.00 and without for 16.00
Old Dec 24, 2013 | 12:01 AM
Cool.
One last thing if anyone reads this far. When I took the blower motor off I notice that there was some old gasket or silicone on the plate, I cant tell exactly as its really deteriorated. I guess its there to to keep it all watertight and probably help with vibration. What should I use when I put it back?
Old Dec 24, 2013 | 05:02 AM
I use RTV. I think the factory used dumdum.
Old Dec 24, 2013 | 06:20 AM
m371961's Avatar
I use 3M strip caulk rolled out thin. Very handy stuff to have around the garage
Old Dec 24, 2013 | 08:52 AM
Strip caulk is what the factory used. You can also use something just as easy - plumbers putty.
Eric - only dumdum I ever heard of was in school and on the toons....
Old Dec 24, 2013 | 09:23 AM
Dum dum is a type of non-hardening putty - I guess like what you're calling "strip caulk," which I've never heard of.
Old Dec 24, 2013 | 09:43 AM
Tedd Thompson's Avatar
All the big holes (firewall area) in every fifties era car that I ever worked on were loaded with dumb dumb and it would still be flexible a 1/2 century after it was installed...Tedd
Old Dec 24, 2013 | 08:11 PM
Lady72nRob71's Avatar
Any motor should work fine and you can reuse your fan as long as the part is made correctly. If it fails sooner, at least it is simple to replace in these models (assuming it has AC).
3M strip calk is my favorite sealer. Used it for lots of automotive uses.
Old Dec 24, 2013 | 08:59 PM
I guess I have a choice between the dumdum, the strip calk and some stuff called RTV sealant. I think I want to try the RTV.
I want to thank everyone who posted their thoughts, you've all been a lot of help.
Old Dec 29, 2013 | 06:41 PM
For fun I looked into the DumDum. It is no longer available due to the shortage of natural resources that it's made from.
That stuff must have been the best.
Old Dec 29, 2013 | 06:46 PM
Hmm, maybe dum dum was made from Do do's - another extinct breed..
Old Dec 29, 2013 | 06:59 PM
Lol
snookys71olds
Feb 21, 2012 09:07 PM
jag1886
Oct 29, 2010 05:06 PM
redvettemike
Sep 6, 2010 07:06 PM
Redog
Nov 30, 2007 06:22 AM
Luckyme1870
Aurora
Jul 26, 2007 05:05 AM
