Another decode my Vin request
Old Nov 10, 2014 | 05:46 AM
Blase's Avatar
Well I searched this site and others trying to get the VIN on my 1953 Oldsmobile 88 decoded but I've had no luck. Can someone here help?
VIN=538M93729
Thanks in advance.
EDIT: BTW I'm not really sure the model. I know its an 88 but is it a Holiday, Delta, Sedan ??? I'm a little lost on how to tell all of that. I'm new to old cars.
Old Nov 10, 2014 | 06:08 AM
jaunty75's Avatar
1953 Oldsmobile Super 88 built at Lansing, Michigan.
VIN's back in the '50s and '60s didn't tell you much about the car that you couldn't figure out just by looking at it. About the only thing it revealed that you couldn't tell is where it was built.
This is the link you want to keep handy:
http://www.v8cars.hu/oldsvin/decode.php
Old Nov 10, 2014 | 06:19 AM
jaunty75's Avatar
What's the body style? Two-door? Four-door? Hardtop?
It's not a Delta as that name wasn't used by Oldsmobile until 1965. "Holiday" was simply Oldsmobile's term for a hardtop (no center pillar). A two-door hardtop was called a Holiday Coupe while a four-door hardtop was called a Holiday Sedan. For '53, though, there was no 4-door hardtop, so the only "Holiday" offered that year was the 2-door hardtop Holiday Coupe, and it was offered only on the Super 88 and 98.
The base 88 came in only two body styles, the "2-door sedan" and "4-door sedan." This can be a bit confusing when compared with other years as the term "sedan" was often used to mean a four-door car, regardless of whether it was hardtop or pillared, not to distinguish between pillared and pillarless.
All '53 Oldsmobiles came with the 303 V-8 that Olds first introduced in 1949. For '53, the base 88, called the "Deluxe 88," came with a 150 hp version while the Super 88 and 98 came with a 165 hp version. A 170 hp version was standard in the 98 Fiesta convertible.
Old Nov 10, 2014 | 06:27 AM
jaunty75's Avatar
Here's a few pages out of the '53 Olds brochure showing the various Super 88 models.
4-door and 2-door sedans:
2-door Holiday Coupe and convertible:
Rocket engine:
12-volt ignition:
Specs:
Old Nov 10, 2014 | 06:54 AM
Blase's Avatar
Thanks. It's like the Yellow one so its a "super 88 Sedan" correct.
below is a couple of photos.
Where I found it sitting. had been here for 6+ years. Whole ran and drove when parked thing.
had it towed home and then I pulled it from behind my shop to my house to clean it up (no water at shop)
Simple green bath.
CLR bath!!!!!!
Passenger side close up after simple green but before CLR & scotch bright.
After CLR and Scotch Bright!!!
Old Nov 10, 2014 | 06:57 AM
jaunty75's Avatar
Yes, that's a Super 88 2-door sedan. Very nice car. Congratulations on saving it. Looks like it will make a nice restoration. Thanks for the photos.
Old Nov 10, 2014 | 07:23 AM
Blase's Avatar
One more question........... for this thread anyway.
Does it have points or a true electronic distributor?
Old Nov 10, 2014 | 07:31 AM
jaunty75's Avatar
Electronic ignition wasn't introduced by Oldsmobile until 1974. Your car was born with a breaker-point ignition system.
http://www.gasenginemagazine.com/gas...n-systems.aspx
tru-blue 442
Jan 14, 2015 04:33 PM
442b
Apr 22, 2012 06:32 PM
mrohler
Jan 28, 2010 05:50 AM
MDC
Dec 5, 2008 10:33 PM
don1903
Nov 7, 2006 09:13 PM
