Air Conditioning
Old Feb 19, 2018 | 04:06 PM
Jfedders's Avatar
Air Conditioning
I have a 1970 350 Cutlass s holiday coupe that had or has A/C but it doesn't have the compressor and I am wondering how to rig that up I was also wondering if the alternator is supposed to go on the driver side or the passenger side because I got the car and it was on the passenger side but I have a friend that says it is supposed to be on the driver side. Who is right
Old Feb 19, 2018 | 04:17 PM
AC cars have the alternator on the drivers side.
Non-AC cars have the alternator on the passengers side.
Below is what the AC system looks like under the hood.
edit:
I found this image that shows a different view. Ignore the text; the pic was from a how-to for heater core R&R.
Old Feb 19, 2018 | 07:14 PM
Jfedders's Avatar
Thank you I was also wondering how could you tell if you had A/C in your car?
Old Feb 20, 2018 | 05:04 AM
An easy way to tell besides the position of the alternator is to look for the condenser in front of the radiator. Here's a basic diagram of an auto AC system.
Old Feb 20, 2018 | 06:08 AM
Jfedders's Avatar
Thank you once again. Also would there be any way to tell if you had air conditioning from the interior of the car
Old Feb 20, 2018 | 07:10 AM
Well, the HVAC control panels are different. One says "HEATER" at the top and one says "AIR CONDITIONING".
Old Feb 20, 2018 | 08:17 AM
Jfedders's Avatar
So let me get this straight if it has air conditioning it has a compressor and the radiator and all that stuff but if it says heat then it doesn't have all that
Old Feb 20, 2018 | 08:19 AM
Yes. Not a lot of reason to install those parts on a car WITHOUT A/C.
Old Feb 20, 2018 | 09:17 AM
Jfedders's Avatar
Thank you so much
Old Feb 20, 2018 | 10:22 AM
jaunty75's Avatar
Now here I thought a guy whose name is Fedders would know all there is to know about air conditioning.
http://www.fedders.com/collection/climate_control.html
When I was a kid in the 1960s, we had a Fedders brand window air conditioner in our house!
Old Feb 20, 2018 | 10:50 AM
Jfedders's Avatar
Not all Fedders are from the exact same family even though we are all related somehow.
Old Feb 20, 2018 | 10:57 AM
jaunty75's Avatar
I thought you were just born with it!
Old Feb 21, 2018 | 09:42 AM
Jfedders's Avatar
Another question I have is what is the difference in diagrams between just having heat and having Air Conditioning. cause I am still kinda fuzzy on what the difference is.
Old Feb 21, 2018 | 10:18 AM
Which "diagrams"?
Heat-only simply uses hot engine coolant circulated through a heater core (a small radiator) in the HVAC box under the dash.
A/C has TWO separate systems - a similar heater that circulates hot coolant and a SEPARATE system that circulates freon through an evaporator core (also a small radiator). The two fluid systems (freon and engine coolant) are completely separate. A flapper door inside the HVAC box (the door is called a temperature blend door) regulates how much hot air from the heater core and cold air from the evaporator reach you inside the passenger compartment.
Get a Chassis Service Manual for your car and read Chapter 1.
If you are talking about the diagram in post #4 above, that is ONLY the A/C part of the system (the freon loop). It does not show the heater part of the system. If you only have a heater, NOTHING in that diagram is installed on your car. If you are thinking this is like a heat pump, it is not. You don't get both heat and cold from the same system. It's like having a hot water radiator in your house for heat and a window air conditioner for cooling.
Old Feb 21, 2018 | 11:03 AM
Jfedders's Avatar
Ok thanks that clears it all up thank you very much Joe
rand5204
Apr 10, 2012 06:37 AM
68Tom
Apr 8, 2009 10:48 AM
68Tom
Apr 4, 2009 01:53 PM
RPD1659
May 21, 2008 07:03 PM
vomer
Intrigue
Apr 29, 2008 04:14 PM
