AC blower
Old Jul 26, 2017 | 04:46 PM
josesexpress's Avatar
AC/Heater Blower
It runs on high speed only and feel cold / hot air but not come out the vents fast or high speed
Old Jul 26, 2017 | 06:32 PM
AC blower
Blower on at high speed only speed that works can feel cool air but not coming out the vents
Old Jul 26, 2017 | 07:05 PM
1970cs's Avatar
Lansing built
Help us out! What are working on? If this an A body it could be the fuse that's located on the driver's side fender liner???
Old Jul 26, 2017 | 09:39 PM
64Rocket's Avatar
Check the blower motor resister.
Gene
Old Jul 27, 2017 | 05:14 AM
... And connect your vacuum lines.
Old Jul 27, 2017 | 05:15 AM
If your fan only runs on HI speed it's likely that the resistor in the AC plenum is bad. This is a common problem on Oldsmobiles through out the years. You can access the resistor from the engine bay, it's mounted in the AC box on the fire wall.
BTW, I merged your threads.
Old Jul 27, 2017 | 09:56 AM
Yep. No vacuum means the air blows out the floor vents only.
Many times the hose to the vacuum reservoir on the firewall is disconnected.
This thread has a lot of pictures and info about a similar issue.
https://classicoldsmobile.com/forums...s-supreme.html
Luckyme1870
Aurora
Jul 26, 2007 05:05 AM
TECH9TWISTA
Jun 25, 2007 12:05 PM
Furr442
Feb 26, 2007 05:29 PM
allthumbs
Dec 27, 2006 08:18 AM
