72 CS Door weatherstripping
Old Nov 2, 2013 | 07:52 PM
MrTorresJr's Avatar
In the next few weeks I am looking into replacing my decrepit weatherstripping, I read some of the prior threads about how using the Metro brand from rockauto.com would be ideal. I will also be using the 3M adhesive & adhesive remover, should I buy any special tools for the project? Thanks in advance.
DT
Old Nov 2, 2013 | 08:44 PM
Nope, a small flat blade screwdriver will do just about all you need.
Old Nov 3, 2013 | 04:33 PM
Lady72nRob71's Avatar
You will also need a sharp utility knife and some wood or plastic scrapers to remove dried adhesive. Popsicle sticks or sections cut from a CD work well on the cheap.
Make sure you save the little black plastic 'push-pins' if they come out intact. If they do not, you might need to buy some. The ones that came in my metro kit were horrible - the heads broke off from finger pressure.
Aside from that minor issue (which could have been fixed since then), the product is great!
Old Nov 3, 2013 | 04:55 PM
Well that pretty much covers it. But I'll add rubber gloves for those who hate getting that stuff on their hands.
Rocketbrian
Jul 22, 2014 09:00 AM
AZ455
Jan 19, 2012 07:27 PM
wjustinmartin
Feb 26, 2010 10:59 AM
Omicron
Jul 5, 2008 09:03 PM
Doug69Cutlass
Apr 15, 2008 04:50 PM
