72 CS Door weatherstripping
In the next few weeks I am looking into replacing my decrepit weatherstripping, I read some of the prior threads about how using the Metro brand from rockauto.com would be ideal. I will also be using the 3M adhesive & adhesive remover, should I buy any special tools for the project? Thanks in advance.
DT
DT
You will also need a sharp utility knife and some wood or plastic scrapers to remove dried adhesive. Popsicle sticks or sections cut from a CD work well on the cheap.
Make sure you save the little black plastic 'push-pins' if they come out intact. If they do not, you might need to buy some. The ones that came in my metro kit were horrible - the heads broke off from finger pressure.
Aside from that minor issue (which could have been fixed since then), the product is great!
