67 cutlass 330 4bbl
67 cutlass 330 4bbl
Recently I purchased a 67 cutlass and there was an adapter plate on the intake with a 2bbl on it. I bought a q-jet and rebuilt it(7027036), but now there is no spot to hook up the throttle cable. I searched the numbers for the carb and it says that it fit this exact year and engine. Any suggestions?
67 did not use a throttle cable. They all used a rod to the throttle linkage at the firewall. I can do this set up if you need it.
email me direct: lemoldsnut@aol.com
Larry
Larry
Welcome to the site. The 67 did not use a cable it had a throttle control rod that came off of an actuator for the transmission torque converter and passing gear if equipped with an automatic, or a belcrank assy for a standard.
Sounds like lemoldsnut has the setup you need. The piece you need on the carburetor has a plastic eyelet where the throttle rod attaches. The throttle rod, bellcrank and accelerator peddle mechanism are specific to what transmission you have.
So this grommet sits in the throttle lever of the carb and then the rod fits through the opening and attaches back at the firewall?
HiCompOlds
July 9th, 2014 06:31 PM
lindaledft
October 31st, 2013 07:37 PM
