330 engine Cutlass 67 4bbl Service Manual
Old Jul 31, 2008 | 11:18 AM
andrekbelo's Avatar
Question 330 engine Cutlass 67 4bbl Service Manual
hi! i´m restoring my cutlass supreme holiday 67 and now is time to fix the engine..the car is stoped by 36 years until now, so it has 9857 miles but the engine has manny rust and locked!
please, i need the manual service for this engine!
thanks
andrekbelo
Old Jul 31, 2008 | 12:40 PM
Oldsguy's Avatar
Past Administrator
Andre,
You might be able to find a Factory Service Manual on Ebay. I think there is a company that sells those on a regular basis. Another member might have some more specific information on that. About your engine being locked up, you may be right, the rings may have rusted to the cylinder walls. You may be able to break it free if you use a chemical agent like PB Blaster. It is available here in the USA but don't know about Brazil. Actually, even a generic oil may do the trick; remove all the spark plugs and squirt some oil down each cylinder and let is soak for a few days. If it appears that the oil is seeping down into the crankcase add some more periodically. After a while see if you can break it free by removing all the belts and pulleys and using a 3/4 inch drive socket on the nut on the end of the crank in the middle of the harmonic balancer. You may need a short extension and using the longest/largest breaker bar will make it easier. Good luck and welcome to our site.
Old Aug 1, 2008 | 02:46 AM
88 coupe's Avatar
Junior Member
Originally Posted by andrekbelo
........ i need the manual service for this engine!
http://www.faxonautoliterature.com/p...456505A5D33003
Old Aug 1, 2008 | 05:05 AM
Oldsguy's Avatar
Past Administrator
I new there was a source, thanks for the help Norm.
Old Sep 1, 2008 | 02:03 PM
Hey Norm,
I for one don't think you are an irritant. You post a lot of good comments. I first saw your "negative" add on when I was asking for info on plastic chrome plating. (good information from everyone thanks very much)
I sure wish you'd lose that part of your signature. I don't think it's fitting for you. And for newbies to this site it might actually make them think you don't know what you're talking about. This site is supposed to be about and for Olds car guys. Please don't take that comment and hold onto it like a grudge to make your point. Your comments have been positively made many times over my friend.
I could have done this as a pm, but I think its important to all of us to know that we need to respect each other as much for our shared opinions, but also for our differences. Easier to smile than to frown right?
Old Sep 1, 2008 | 04:04 PM
66 Olznut's Avatar
Ca's Only Official OLZNUT
I know Norm and my best friend Spence has known him for alot of years. Norm knows his chit, bottom line.
Old Sep 1, 2008 | 07:05 PM
Thanks Olznut. I knew there were people out there who shared the same thoughts on Norm.
Old Sep 1, 2008 | 08:10 PM
Tell Spence I said hi. I haven't seen him since I left SoCal in 1987.
Old Sep 1, 2008 | 08:23 PM
66 Olznut's Avatar
Here's a pic of him and his car a few years back, the same '65 socal22.jpg And here's a vid of him being interviewed at this year's All GM Show. http://www.livecarshows.com/2008LCSshows.html Go to the site, to 2008 shows, then All GM 2008, he's about 15 minutes into it, you might recognize a few others as well.
I just talked to him and he remembers you and the flip nose car you had. He still has an article of it from a magazine it was in. I see him almost every weekend since we live in the same area. He started rambling about old times, especially times when we all went to Terminal Island to race, hahaha!! I've known Spence since 1988 when I turned 16 and part of the OCA and So Cal since then as well. Too cool, I asked him if he knew someone named Joe and your name came up almost instantly!!
Old Sep 2, 2008 | 02:54 PM
88 coupe's Avatar
Junior Member
Originally Posted by Allan R
........ I for one don't think you are an irritant ........
What does this have to do with Service Manuals?
........ Easier to smile than to frown right?
What does this have to do with anything?
Instead of trashing someone else's thread, send me a PM, explaining WTF you are talking about.
Norm
Old Sep 2, 2008 | 03:01 PM
88 coupe's Avatar
Junior Member
I know Norm ........
When I get to the point where I need help defending my own posts, I will quit posting.
Norm
Old Sep 2, 2008 | 04:25 PM
88 coupe's Avatar
Junior Member
The small number of troublemakers who resort to personal attacks when they are unable to defend their erroneous (if not downright BS) posts, are either gone or are stopping to think before they press the "send" button.
And that is, as it should be.
The large percentage of members who do read (and understand) what was actually written, have been aware of the facts since the beginning.
Norm
Boldsmobile
Dec 13, 2015 07:16 PM
Bobac455
Feb 6, 2014 02:04 PM
May 22, 2012 07:22 PM
MaxDog
Jul 21, 2011 11:50 AM
Del70
Jul 6, 2011 03:46 AM
