67 442 engine
Old Mar 5, 2013 | 02:59 PM
bend442's Avatar
67 442 engine
What's the best way to verify that a 67 442 has a 67 400 motor? Are there certain casting numbers or other info on the block that I should look for. I know there is some information on the web regarding this info, but I wanted to pose this question to this forum.
Old Mar 5, 2013 | 03:02 PM
Oldsmaniac's Avatar
On the block front near just behind water pump should be a large letter E. That will verify a 66 or 67 400. Then by #1 spark plug, just to the left should be a C and that will be the proper letter heads for a 67 400
Old Mar 5, 2013 | 03:05 PM
Oldsmaniac's Avatar
A picture
Old Mar 5, 2013 | 04:09 PM
Octania's Avatar
Then look on the end of the C head. Fwd end of RH head, or aft end of LH head if they have been off -n- swapped:
"Stamped" there- and I mean by hitting a stamp with a hammer- not a cast-in feature- is the Engine Unit Number. The E400 442 engine will be stamped
V101123G
Where the V and G indicate the application, and the 6 digits between [above is obviously a contrived example number] are the engine's sequential ID number, useful only if you have a protecto-plate to match it.
Any chance your engine's car has the POP in the glovebox? _That's_ documentation.
Old Mar 5, 2013 | 04:35 PM
RocketPower442's Avatar
E Block and C heads. But that is vague lol
Old Mar 5, 2013 | 05:17 PM
bend442's Avatar
Thanks ......... your comments will help.
805cut
May 3, 2012 08:11 PM
Olds luvr
Mar 17, 2010 06:57 PM
njot33
Sep 25, 2009 09:07 AM
cts-v
Jan 10, 2009 06:20 PM
pinky
Oct 1, 2007 11:24 AM
