'52 Olds fuel pump- how do you test it
I have a 1952 Olds Super 88 with a 303 engine. The car starts great but it's not running right. It's sputtering, loping and misses under a load. I've drained the gas tank thinking that was the problem but it didn't help. I've also replaced the spark plugs. . . still not right. Does anyone know how to test the dual-action fuel pump??? Could this be the problem???
Thanks!
Thanks!
I agree it doesn't sound like a fuel pump but a easy way but not definitive( it won't be under any pressure) way to check a fuel pump can be achieved by removing the fuel line at the carburetor, put a 16 oz coke bottle on the fuel line then with the coil wire removed crank the engine over for 8 to 10 seconds it should fill the bottle about 1/2 full, if not pump is probably bad or could be theirs an air leak in the fuel line before the pump. Let us know how you come out on this...Tedd
shamusj
March 4th, 2016 06:48 AM
RenderPit
Ninety-Eight
August 6th, 2015 04:55 PM
