'52 Olds fuel pump- how do you test it
Old Nov 8, 2014 | 06:24 AM
jmills's Avatar
I have a 1952 Olds Super 88 with a 303 engine. The car starts great but it's not running right. It's sputtering, loping and misses under a load. I've drained the gas tank thinking that was the problem but it didn't help. I've also replaced the spark plugs. . . still not right. Does anyone know how to test the dual-action fuel pump??? Could this be the problem???
Thanks!
Old Nov 8, 2014 | 06:30 AM
Doubtful its the fuel pump. I would check dwell, timing, and carb settings. Look down into the carb and see if its drippling fuel while idling.
Old Nov 8, 2014 | 07:30 AM
Tedd Thompson's Avatar
I agree it doesn't sound like a fuel pump but a easy way but not definitive( it won't be under any pressure) way to check a fuel pump can be achieved by removing the fuel line at the carburetor, put a 16 oz coke bottle on the fuel line then with the coil wire removed crank the engine over for 8 to 10 seconds it should fill the bottle about 1/2 full, if not pump is probably bad or could be theirs an air leak in the fuel line before the pump. Let us know how you come out on this...Tedd
shamusj
Mar 4, 2016 06:48 AM
RenderPit
Ninety-Eight
Aug 6, 2015 04:55 PM
Tedd Thompson
Jul 13, 2015 06:50 AM
pcard
Mar 15, 2013 12:44 PM
IB Adrian
Sep 12, 2009 12:43 PM
