455 rebuild
Old May 19th, 2012, 11:03 PM
olds 88's Avatar
455 rebuild
i got a 455 i want to put in my car what would you do to it to make it the best it can be thanks
olds 88 is offline
Old May 20th, 2012, 05:21 AM
Olds_71_442's Avatar
I was thinking of starting a thread like this too. I'd like to beef mine up to be just below the point where I start breaking stuff.
I wonder if any of the guys who have rebuilt their engines could help us out here?
Olds_71_442 is offline
Old May 20th, 2012, 11:58 AM
blueohbaby's Avatar
I rebuilt a 455 about 3 years ago. The first thing to know is it isn't cheep. I put a full 4340 rotating assembly in it, 10.7-1 compression, fluiddamper, MSD ignition, Ross pistons, Be Cool radiator and a 930? Demon i think. It runs strong but was very expensive. I dont know why Olds engine parts cost so much more than the other GM parts but they do. I have found the best street cams are the ones designed for a jet boat. They are off idle to 5000 and make really good torque.
blueohbaby is offline
Old May 20th, 2012, 12:19 PM
69350rocket's Avatar
Depends mostly on how much you want to spend. Are you looking to do a full build or just a few things to get some more power? And also what heads does it have on it?
69350rocket is offline
Old May 20th, 2012, 02:23 PM
olds 88's Avatar
it needs a full rebuild i was not wanting to spend over 1500 on it and i don't know what heads r on it i will let u know win i pick it up
olds 88 is offline
Old May 20th, 2012, 04:18 PM
If your rebuilding then go with a set of flat top pistons, and ARP rod and main bolts and it should be fairly solid. If the engine has J heads, then junk them and get a different set. For a cam I would recommend you have Cutlassefi custom grind one for your setup. Then top the setup off with an Edelbrock Performer intake. If your running an automatic then you might want to think about getting a mild stall converter also.
Old May 20th, 2012, 05:02 PM
In my case, I'd like to spend whatever it takes to make some power. But I'd rather it use normal pump gas and be just shy of the power needed to blow transmissions or rear ends.
Old May 20th, 2012, 06:08 PM
Tvan's Avatar
Also interested in this topic. I have a 1968 455 with "C" heads that I would like to rebuild from the bottom up. Mine is in my '65 442 with a 4 speed manual transmission.
Tvan is offline
jensenracing77
January 12th, 2016 02:02 PM
442dreamer
August 23rd, 2011 07:28 AM
Gary's 2 442-S
August 14th, 2011 12:04 PM
442oldslawyer
April 29th, 2010 09:22 PM
72Cutlass
October 26th, 2007 05:45 PM
Quick Reply: 455 rebuild
