455 rebuild
I was thinking of starting a thread like this too. I'd like to beef mine up to be just below the point where I start breaking stuff.
I wonder if any of the guys who have rebuilt their engines could help us out here?
I rebuilt a 455 about 3 years ago. The first thing to know is it isn't cheep. I put a full 4340 rotating assembly in it, 10.7-1 compression, fluiddamper, MSD ignition, Ross pistons, Be Cool radiator and a 930? Demon i think. It runs strong but was very expensive. I dont know why Olds engine parts cost so much more than the other GM parts but they do. I have found the best street cams are the ones designed for a jet boat. They are off idle to 5000 and make really good torque.
it needs a full rebuild i was not wanting to spend over 1500 on it and i don't know what heads r on it i will let u know win i pick it up
If your rebuilding then go with a set of flat top pistons, and ARP rod and main bolts and it should be fairly solid. If the engine has J heads, then junk them and get a different set. For a cam I would recommend you have Cutlassefi custom grind one for your setup. Then top the setup off with an Edelbrock Performer intake. If your running an automatic then you might want to think about getting a mild stall converter also.
72Cutlass
October 26th, 2007 05:45 PM
