455 buick motor
455 buick motor
hi can sumeonehelp me my motor started running rough and blowing out oil throught the breather. now has a slight pinning noise when you take the breather out and listen. thinking it might b the compression rings
From your description something is allowing compression to blow down into the crankcase. Do a compression test for a cylinder with low pressure. You might find it before that when you pull the spark plugs to do the test if you find a really oily plug. Unless you can overhaul an engine and have the right tools you will need a mechanic. I know there are a ton of hot rods in NZ and quite a few Kiwis here in the States that specialize in sending American hot rods back home so you can probably get parts or even a different engine if it gets that serious. Good Luck.
If it's blowing oil out the breather, I agree: Holed piston or cracked rings (and piston, usually).
By the way, welcome to ClassicOlds, and... Why are you asking questions about a Buick motor on an Oldsmobile site?
BLACKCADDY
June 2nd, 2015 09:38 AM
Jayycobb
Drivetrain/Differentials
December 6th, 2011 07:27 AM
f-85
January 11th, 2009 09:31 AM
