455 buick motor
Old Jan 16, 2014 | 08:59 PM
lucky 1's Avatar
455 buick motor
hi can sumeonehelp me my motor started running rough and blowing out oil throught the breather. now has a slight pinning noise when you take the breather out and listen. thinking it might b the compression rings
Old Jan 16, 2014 | 10:42 PM
47 Convertible's Avatar
From your description something is allowing compression to blow down into the crankcase. Do a compression test for a cylinder with low pressure. You might find it before that when you pull the spark plugs to do the test if you find a really oily plug. Unless you can overhaul an engine and have the right tools you will need a mechanic. I know there are a ton of hot rods in NZ and quite a few Kiwis here in the States that specialize in sending American hot rods back home so you can probably get parts or even a different engine if it gets that serious. Good Luck.
Old Jan 17, 2014 | 09:39 AM
It can also be a sticking lifter or it's got dirt in it not allowing it to pump up all the way.
Old Jan 17, 2014 | 09:42 AM
Octania's Avatar
Sounds like a hole in the piston to me.
compression and leakdown tests, followed by teardown and inspect as necessary.
Old Jan 17, 2014 | 10:24 AM
If it's blowing oil out the breather, I agree: Holed piston or cracked rings (and piston, usually).
By the way, welcome to ClassicOlds, and... Why are you asking questions about a Buick motor on an Oldsmobile site?
Old Jan 17, 2014 | 10:26 AM
Because it's in his Oldsmobile.
Old Jan 17, 2014 | 10:38 AM
Oh. Right. Of course.
You a private investigator or something?
I found it in the captions inside of his photo galleries, which have no photos in them.
Thanks... I guess...
BLACKCADDY
Jun 2, 2015 09:38 AM
ralsy
Jun 30, 2012 04:22 PM
Jayycobb
Drivetrain/Differentials
Dec 6, 2011 07:27 AM
ctrain22
May 20, 2009 11:02 PM
