350 rocket mild modifications
Old November 21st, 2016, 10:38 AM
turley68delta88's Avatar
Wanted to ask a restoration question and then a modification question. I have an automatic and when my car tries to change gears when accelerating it screeches and then slams the gear sometimes even very late just wondering what that could be if anyone could help me out on that??? Also, after I get that fixed I want to start making upgrades as far as performance and thought I'd start with a Holley 4 bbl vacuum secondary single inlet carb, a new summit racing header-back dual exhaust system, and new headers, but not sure which ones I should get. Hedmen Hedders seem to have quality headers for a fair price but any advice would be greatly appreciated and this car would only be for street use I just wanted to add some more horsepower to my Oldsmobile and get it running better
turley68delta88 is offline
Old November 21st, 2016, 10:47 AM
The first question is, what trans do you have in your 68 - TH400 or Jetaway?
As for the mods, no one makes headers that will fit the 1965-70 Delta 88s. They have a unique rear steer configuration and there isn't room for headers. You won't really be able to run dual exhaust on your 350. These cars require a unique exhaust manifold on the driver's side to clear the steering box and starter. Unfortunately, the 1965-70 D88 was never offered with dual exhaust on the small block. so that manifold (which is available as a repro) was only offered for the big block. I recently installed one on my 67 D88, and the configuration MAY fit an SBO, but no guarantees.
A properly rebuilt Qjet will perform better than any Holley, especially on a heavy car like a D88 with a small block. I wouldn't waste my time or money on a different carb. Start by getting your stock configuration properly tuned up and fix any maintenance issues and THEN worry about mods.
joe_padavano is offline
Old November 21st, 2016, 11:24 AM
thanks for the response, I know it has a newly rebuilt trans but I don't know exactly what it is, also currently it does have a dual exhaust system set up and I have had problems with it there was an exhaust leak and I got that fixed but it still makes a clicking noise after driving it for a while, and I did find out that the exhaust had been rubbing on the drive shaft so I'll just go with the single exhaust and have the carb rebuilt, thank you very much!
Old November 21st, 2016, 11:45 AM
I'm curious as to how the driver's side pipe was routed. My 67 had a custom bent dual exhaust system when I got it, using the single exhaust manifold on the driver's side. The pipe was flattened to almost nothing to get it past the starter and steering linkage. That's why I swapped to the correct exhaust manifold and new pipes.
Old November 21st, 2016, 03:47 PM
Mine is custom as well I believe I just looked at it and it goes up and over the the rear axle shaft
Old November 21st, 2016, 04:40 PM
For your shifting problem, check the vacuum line to the modulator for damage and make sure its hooked to manifold vacuum and that vacuum is present at the trans.
oldcutlass is online now
Old November 21st, 2016, 05:33 PM
Okay thank you! I'll check that tomorrow when I have time👍
Old November 21st, 2016, 05:35 PM
also I was wondering what a good website I could use to check my vin I've had no luck so far
Old November 22nd, 2016, 05:17 AM
I'm talking about where it connects to the exhaust manifold at the engine.
Old November 22nd, 2016, 05:19 AM
What do you want to check it for? None of the Carfax-type sites will take a VIN this old that only has 13 digits. If you just want to decode it, post it here. There is very little info in the VIN - it's all what you can see by looking at the car. All it will tell you is that it's an Oldsmobile, the specific model and body style, the year, and the assembly plant.
Old November 22nd, 2016, 08:25 AM
What I could see was it goes around my oil filter and under the oil pan and straight up into the manifold and okay I won't get the vin checked then if there's no need thank you👍
Old November 23rd, 2016, 08:30 AM
The passenger side exhaust pipe just goes straight up into the manifold
Old November 23rd, 2016, 08:39 AM
So the DRIVER'S side exhaust pipe runs under the oil pan and down the PASSENGER side of the car???
Old November 23rd, 2016, 06:17 PM
Yeah it does and I thought the engine was a 350 because when I took the car to a mechanic recently I had told him it was a 455 but when he inspected the car he told me it was a 350, but I just called my uncle who's the person that sold the car to me and he said it's the original 455 so that must be why it fits like that
Old November 23rd, 2016, 08:14 PM
[QUOTE=turley68delta88;970236]Yeah it does and I thought the engine was a 350 because when I took the car to a mechanic recently I had told him it was a 455 but when he inspected the car he told me it was a 350, but I just called my uncle who's the person that sold the car to me and he said it's the original 455 so that must be why it fits like that[/
I don't know why that mechanic said it was a 350 but my uncle said its the original 455 with the original miles and I did find out it has the original 350 turbo automostic transmission I'm honestly not familiar at all really with transmissions but he said he had recently had it rebuilt before he sold it to me
Old November 24th, 2016, 02:52 AM
svnt442's Avatar
I don't know why that mechanic said it was a 350 but my uncle said its the original 455 with the original miles and I did find out it has the original 350 turbo automatic transmission I'm honestly not familiar at all really with transmissions but he said he had recently had it rebuilt before he sold it to me
That doesn't make sense. Being a 1968 car it should have a TH400 seeing as the TH350 was not put into cars until 1969. And besides that, GM wouldn't put a TH350 behind a 455 anyhow.
svnt442 is offline
Old November 24th, 2016, 06:50 AM
The block casting number above the water pump will tell you exactly what engine that is with no uncertainty.
Old November 24th, 2016, 12:36 PM
My uncle owned the car before me and he said and so I asked him what the transmission was and he said it was the 350, but wasn't sure so it probably is just the TH400
Old November 24th, 2016, 12:45 PM
Okay thank you very much!👍
Old November 24th, 2016, 12:46 PM
The number is 396021 F
Old November 24th, 2016, 01:08 PM
Unhappy 455 engine identification
Wanted to know exactly what engine I have the number is 396021 F
Old November 24th, 2016, 01:23 PM
That is a 455.
Fun71 is offline
Old November 24th, 2016, 01:25 PM
That is the block casting number for all 455s from 1968 through 1976.
To know exactly which 455 it is would have to be determined from the application, which in your case (if I remember your posts correctly) is a 1968 Delta 88 455-4bbl dual exhaust.
I don't have ready access to the 1968 engine specs but they are likely the same as 1969 which was 10.25:1 compression ratio, 365 hp @ 4600 RPM and 510 lb-ft @ 3000 RPM.
Fun71 is offline
Old November 24th, 2016, 01:34 PM
That is a 455.
Thank you!
Old November 24th, 2016, 01:41 PM
Okay thank you, I don't know for sure though if it is 4 bbl with that high of hp and torque ratings I thought it would be maybe the lowest with 310 hp and 490 lb-ft torque but when the car was running how it should it was suprisingly fast so I don't know
Old November 24th, 2016, 02:06 PM
I think the 310 / 490 engine is the low compression 2bbl version.
Fun71 is offline
Old November 24th, 2016, 03:42 PM
Yeah I know I think that's what I might have, in my earlier post I just said I was thinking of putting a 4 bbl carb in there if I could but I'm just going to rebuild the carb and worry about regular maintenance for now
Old November 29th, 2016, 09:58 PM
GoodOldsGuyDougie's Avatar
This was a fun read.
GoodOldsGuyDougie is offline
oldzy
December 27th, 2010 08:38 PM
jeffreyalman
April 29th, 2010 11:31 AM
jlowery
May 14th, 2009 02:06 PM
diamondave
August 29th, 2008 01:29 PM
jrbarrie83
June 8th, 2005 05:14 PM
Quick Reply: 350 rocket mild modifications
