330 pulleys
330 pulleys
Hi all,
I'm new on the forum I'd like to say hello to all and hope I'm posting this in the correct section.
I've been search forums and the internet for a few days but can't find any solid info.
I'd like to know if pulleys (crank, steering, alternator) from a 350,455 fit on a 330.
If not where can i find a complete pulley kit for a 330? ('67 A-body)
Thanks!
Thanks!
yes and no
As an entire set, including PS pulley and the pump it fits, yes.
Mix & match, not so much.
Slight spacing differences between grooves 1/2 vs 2/3 between pre-68 and post-67 pulley sets comes to mind. Then there's the three different lengths of water pump to deal with.
The engines can be changed in a car and use THE CAR'S
Water pump
PS pump
ALL the pulleys
AC pump
all the bracketry and special bolts and spacers.
and things will go pretty smoothly.
If you change any of these car's pieces, you quickly get bogged down in mismatched stuff that doesn't fit and work right.
Water pump
PS pump
ALL the pulleys
AC pump
I would suggest that you'll find things much easier if you get the complete setup from a 66-67 car.
Welcome to C.O. I agree with Joe. My problem is in reverse. I have a 350 (block #395558)in my '64 Cutlass with the original alt bracket, PS pump and bracket from the original 330. My belts are slightly misaligned. I would like to have all brakets and ps pump for the 350 to correct my situation.
The alternator should be fine. Be sure you have the pulleys that match the length water pump you have (or get a pump that matches the pulleys you get, which might be easier). Be sure you use everything as a matched set, or you almost certainly WILL have belt alignment issues. All 1964-1990 small block Olds motors are externally identical EXCEPT for the water pump and timing tab differences on the 1964 motors.
