1968 engine recommendation
Hey guys, after several days researching the site I️ found myself in a dilemma here. I️ recently pickup a 68 holiday supreme i want to upgrade the engine and transmission money is not a factor however I’m not looking to build a high performance car. So if you guys could be kind enough to offer a few suggestions for engine and trans which will make for an easy swap. Thank you
Find a 455 and TH400 combo and rebuild both with performance in mind. Or an early 400 from a 65-67 442. Keep in mind a 350/TH350 combo can be built to run well.
Since you say you have deep pockets if you really want to go fast call Bill at BTR. He'll figure out something for you. Consider a Tremec 6 speed stick...and a rear end upgrade.
http://www.btrperformance.com/
Texas442
February 23rd, 2017 03:51 AM
