1968 engine recommendation
Old Nov 30, 2017 | 07:18 PM
kercus05's Avatar
Hey guys, after several days researching the site I️ found myself in a dilemma here. I️ recently pickup a 68 holiday supreme i want to upgrade the engine and transmission money is not a factor however I’m not looking to build a high performance car. So if you guys could be kind enough to offer a few suggestions for engine and trans which will make for an easy swap. Thank you
Old Nov 30, 2017 | 08:19 PM
What do you mean by "upgrade"?
What engine does the car currently have?
What are you wanting - high miles per gallon, simple maintenance, or ???
Old Dec 1, 2017 | 07:17 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Find a 455 and TH400 combo and rebuild both with performance in mind. Or an early 400 from a 65-67 442. Keep in mind a 350/TH350 combo can be built to run well.
Since you say you have deep pockets if you really want to go fast call Bill at BTR. He'll figure out something for you. Consider a Tremec 6 speed stick...and a rear end upgrade.
http://www.btrperformance.com/
Old Dec 1, 2017 | 07:34 AM
If your not building for performance, why not rebuild what you have?
Old Dec 2, 2017 | 03:50 PM
Cutlass Fan's Avatar
Simple and reliable. A nearly stock 455 with a built 200r4 trans and mid 3 rear axle. Lots of seat of the pants performance and will cruise easy on the hi way with decent mileage.
Texas442
Feb 23, 2017 03:51 AM
Hawk1061
Jun 6, 2012 07:49 AM
iuhoops83
Mar 17, 2008 05:54 AM
labrats804
Jun 1, 2007 11:13 AM
J'ville
Jul 7, 2006 03:24 PM
