1948 olds series 60
Citcapp, are the engine mounts for a BBO? If so, Could you provide a measurement from center of mount to center of MII crossmember please.
Also, I'm looking for an original brake pedal assembly for my '47 60 series from a hydramatic equipped car. I'd like to do my brakes under the floor.
Thanks for any help.
Jerry
Woodland WA
Jerry
Woodland WA
Yes it's set up for a 455. I'll take the measurement this evening and post it. You could go with a after market hotrod under the floor set up either power or non-power both are available. I found a few on the internet when I was looking around. I decided to go with a hanging pedal setup on my 48. We'll have to get together this spring or summer and compare notes on our builds
Pat
Pat
Pat, a little clarification on the measurements. Was the 6" from center of crossmember to center of mount? Or 6" to the closest edge of the crossmember?
I have to admit I was at a loss to know what 12-1/1" is. Help me out a bit please. I do appreciate that you thought of giving two measures to better locate.
Jerry
Jerry
