Wondering What I would need for a 383 stroker
I’ve been eyeballing this 383 Stroker made by Atk and was wondering what all would i need, I know I would need a new transmission since the Th350 won’t go with the 383 but im wondering what else would i need other than a transmission. Kind of just seeing what i would need for exhaust system, fueling supply, no A/C on the engine but just curious
1984 Oldsmobile Cutlass Supreme Brougham is the Car btw
Do you know any shops or sites that do sell 455 blocks or even partially built ones? Just considering the 383 because of the availability of parts and blocks in my area
https://classicoldsmobile.com/forums...orsepower.html
You could put a 700R4 on the back of the 383, and get overdrive. They should almost be a bolt in. You will need a shortened drive shaft, and an adapter universal for the front. There are TH350s for the 383 as well.
