Tachometer- Needed on automatics?
Old Oct 28, 2017 | 09:08 AM
Christopher Michael Drew's Avatar
Hey guys i'm restoring my 71 and im gonna order and install new gauges from auto meter and make a custom instrument cluster. I dont want to spend 200+ buck on a tach I don't need and never look at when im driving. I could understand if it was a manual car, then the tach would be useful. what are you thoughts? Needed or not needed on a automatic 71 Olds 350?
Old Oct 28, 2017 | 09:39 AM
Cincinnati Rick's Avatar
I think a tach is always a good idea in an automatic. I like seeing what the idle RPM is and if I decide to shift manually, I can, knowing what the RPMs are in each gear
Old Oct 28, 2017 | 10:03 AM
Why not? Since you're doing aftermarket gauges you can install what ever you want.
Old Oct 28, 2017 | 10:46 AM
You can over-rev an automatic nearly as easily as you can over-rev a manual.
Old Oct 28, 2017 | 10:48 AM
If you never do hole shots, race, or rev through the gears, then don't install one.
Old Oct 28, 2017 | 02:18 PM
Automatic or manual trans is irrelevant. A tach provides information about the engine the same as a water temp gauge or oil pressure gauge. I can't imagine driving a car without one.
And there is no need to spend 200+ on a tach when you can get one for $40.
https://www.summitracing.com/parts/bgs-fst-7901
Old Oct 28, 2017 | 02:21 PM
Exactly
Old Oct 28, 2017 | 02:30 PM
The tach i would want would be matching the gauges im getting so it would cost over 200, but i hear you guys, its good to have. Thanks!
Old Oct 29, 2017 | 05:13 PM
Tedd Thompson's Avatar
Plus if you are half def like me it lets me know that the engine is still running and I don't need to hit the starter and embarrass myself in front of my gear head friends. .... Tedd
Old Oct 29, 2017 | 05:21 PM
redoldsman's Avatar
Proud Viet Nam Veteran
I have a column mounted tach in my 54. It is Stewart Warner Wings series which looks correct for the car. My speedometer is about 8 mph slow so I know at 3,000 RPM's I am going about 70 mph (see what 3:36 gears and no overdrive will do). For the most part I really don't need it but I just think it looks cool.
Many people think the tach is not needed on an automatic, but is for a manual, but ignore the fact that you usually shift with your ear and routine muscle motions and hardly ever look at the tach while driving a manual normally.
My priorities: Oil gauge or light....speedometer....temp gauge or light....fuel gauge....tach....voltmeter.....oil temp....transmission temp....I guess a clock
They make nice little 4 in 1 pods that do fuel, temp, oil, and volts. I'd do it, a custom tach, and a speedo. You can look at your phone for the time.
Old Oct 30, 2017 | 05:34 AM
Here's the tachometer I've had for nearly 20 years. It's not in my 71 98 but I guess I should install it (it's just sitting in a box in the garage). I had it installed in a 1990 Buick Estate Wagon and the 1964 Olds 98 I owned.
https://www.summitracing.com/parts/atm-2300/overview/
Old Oct 30, 2017 | 09:31 AM
marty59's Avatar
If for some reason your speedometer fails, you can get yourself close to speed with a tach.
Old Oct 30, 2017 | 10:13 AM
x2
This is why I had the tachometer installed in my Estate Wagon. The speedometer didn't work because the drive gear in the 2004R was worn. Instead of pulling the tail housing and replacing the drive gear I just used the tach.
Old Oct 30, 2017 | 11:09 AM
redoldsman's Avatar
I have two Garmin nav units and they both show the speed limit and my actual speed. If my speed is above the actual speed limit the speed will be highlighted.
Old Oct 30, 2017 | 11:29 AM
droptopron's Avatar
delete
I agree with Oldcutlass but on the flip side if you are doing a custom gauge set up it might look kinda funny to not have the most common gauge.
70cutlasssupreme
Jan 24, 2022 02:30 PM
White_Knuckles
Oct 17, 2012 01:39 AM
guido
Dec 6, 2009 07:49 AM
wazoo
Hurst/Olds
Aug 27, 2009 01:36 PM
Florent.turbo
Sep 10, 2008 01:10 PM
