Steering box
Old Jan 10, 2013 | 05:33 PM
XTREMEGSXR's Avatar
Steering box
When I took my front end apart and the steering box off there was a shim on each bottom bolt between the box and frame. I am putting it back together and someone told me the shims were not supposed to be there. It that correct?
Old Jan 10, 2013 | 05:40 PM
ent72olds's Avatar
Registered Luser
Any I 've ever removed never had shims.......
Old Jan 10, 2013 | 06:32 PM
OLD SKL 69's Avatar
GM Enthusiast
I've never heard of shims located between the frame and steering box. Not sure why they would have been in there in the first place but you never know who worked on your car before you.
Old Jan 11, 2013 | 07:18 AM
Does it show signs of any frame damage for it's past?
Old Jan 12, 2013 | 05:44 AM
XTREMEGSXR's Avatar
I haven't noticed any frame damage. I took measurements and it seemed to be correct. The shims look like they have been there for a long time. It was one shim on the two bottom bolts. The same size shim. Looks like an alignment shim.
Old Jan 12, 2013 | 06:13 AM
ent72olds's Avatar
Registered Luser
How old is the car?
Old Jan 12, 2013 | 10:56 AM
XTREMEGSXR's Avatar
It's a 1970.
Old Jan 12, 2013 | 07:29 PM
ent72olds's Avatar
Registered Luser
It's a 1970.
That's 44 yrs of "something could have happened in the past"....
Old Jan 13, 2013 | 05:24 AM
I see no harm in putting them back in as there was a reason at some point in time, I would assume. The only reason they would be in there would have been some sort of a clearance issue or steering wheel position issue. All steering positions are adjustable, so I don't see why though.
Old Jan 14, 2013 | 05:23 AM
XTREMEGSXR's Avatar
I put it bake with out the shims. Everything seems to look like it's lined up correctly. I included some pics.
agtw31
Suspension & Handling
15
Jun 14, 2010 06:01 AM
MurphTypeR
Drivetrain/Differentials
Dec 10, 2008 06:08 AM
d-666
Oct 2, 2008 03:36 PM
nohn
Jul 7, 2008 11:55 PM
dynamic88
Mar 6, 2008 09:58 AM
