rocker arms???
Old Jul 21, 2012 | 07:12 AM
JOHNNYOLDS442's Avatar
Olds Specialist LOL
rocker arms???
Can sombody let me know the torquw\e for a stock 70 455?
rockers are just 30 pounds???
Old Jul 21, 2012 | 07:20 AM
Octania's Avatar
5/16 grade 8 flange head bolts are 25 ft-lbs oiled.
Old Jul 21, 2012 | 10:41 PM
ah64pilot's Avatar
Octania is right, if you're using the stock rocker arms the book says 25 ft/lbs on the pivot bolt.
Old Jul 22, 2012 | 04:45 AM
Olds Specialist LOL
Do you just tighten down where ever they are or must the valve be in a certain position?
Thanks Guys!
Old Jul 22, 2012 | 01:54 PM
ah64pilot's Avatar
If you have the intake manifold off you need to make sure that you are on the backside of the cam lobe when you torque it. You can see the lifter on the cam surface.
If you have the intake manifold still on it, then finger tighten the bolts and turn the engine until you get all the slack out of the pushrod and the pushrod is sitting as low as it can in the hole...it should then be on the backside or at least off of the lobe. Then torque it down.
Old Jul 24, 2012 | 04:34 AM
Olds Specialist LOL
Thanks AH done just waiting for a buddy to come over and lift that heavy intake back on my car.
That thing is too heavy to do alone!!!
Old Jul 24, 2012 | 10:08 AM
ah64pilot's Avatar
Ouch! I feel you. When I was in high school I used a cast iron intake and had to have my dad help me just to make sure I set it down straight. After pulling it off a few times he said to hell with it, I'm buying you an aluminum intake for Christmas just to save my back...then I spun a rod bearing and never got that intake lol!
Old Jul 25, 2012 | 04:14 AM
Olds Specialist LOL
Still waiting anybody live in N.Y. wanna help lol
Uploaded with ImageShack.us
mdfedewa
Suspension & Handling
Mar 28, 2013 05:38 PM
young olds
Apr 25, 2010 04:15 PM
mmcilroy
Feb 6, 2010 08:28 AM
Atdog
Feb 14, 2009 06:51 AM
mjc79
Oct 18, 2008 10:02 PM
