64 330 shaft mounted rocker arms
Old Apr 24, 2010 | 09:47 AM
young olds's Avatar
Do the 64 330 shaft monted rocker arms fit on any other heads?
Old Apr 24, 2010 | 10:12 AM
64Rocket's Avatar
I say NO. It has been a while since I look at the shaft mounted rockers, but I think the bolt pattern is completely different.
Gene
Old Apr 24, 2010 | 12:36 PM
Run to Rund's Avatar
"no" is the correct answer. Only #1 heads have the special bolt pattern.
Old Apr 24, 2010 | 04:21 PM
X3. Just look at the photos in the 1964 CSM and the differences become obvious.
Old Apr 25, 2010 | 10:36 AM
young olds's Avatar
ok, thanks.
Old Apr 25, 2010 | 12:19 PM
Boldsmobile's Avatar
Old Apr 25, 2010 | 01:04 PM
young olds's Avatar
could those heads be any good on a big block?
Old Apr 25, 2010 | 04:15 PM
Only if your big block is making too much power and you want to choke it down with small block sized ports...
The_German
Jul 3, 2013 08:09 AM
Frogge467
Mar 24, 2012 11:09 PM
dartphil
Sep 28, 2011 02:07 PM
russell-t
Sep 22, 2011 06:37 PM
64 CUTLASS KEN
Nov 22, 2010 05:17 PM
