pulley and brackets
Old Mar 29, 2020 | 12:07 PM
midiowa's Avatar
pulley and brackets
swapped out 330 for the 455, changed water pump, trying to put on power steering and alternator bracket but coming up short 3/8 in to line up threads and tight as hell on valve cover(ok). thinking because of edelbrock performer manifold? not liking fit, also water plug right there where bracket bolts on manifold(in pic), flat plug? what am I missing? plasma a notch for manifold clearance on bracket?
Old Mar 29, 2020 | 04:11 PM
midiowa's Avatar
custom fix with plasma on brackets.. all good
Old Mar 29, 2020 | 04:54 PM
2blu442's Avatar
I'm glad you got it resolved, but when you have everything bolted on the engine would you share pictures with us? The early 400 was used the same time as the 330 and the exterior of the 400 is the same as a 455. So I would have thought the brackets would interchanged. Maybe it was the aftermarket intake? What did you decide? John
Old Mar 30, 2020 | 09:46 AM
midiowa's Avatar
no doubt it was the after market manifold, had to cut off corner of bracket to fit over runner on intake bolt, also had to cut small amount of pad where bolt goes thru onto manifold for alternator bracket. easy fix.
lileyez99
May 14, 2016 03:44 PM
TexasTool
Apr 7, 2016 06:21 AM
68 D88
Feb 16, 2015 05:20 AM
86odls
Mar 20, 2014 04:15 PM
Terryc
Jul 24, 2012 07:47 PM
