Oil pan clearance to crank bolts
I am assembling a 455. My machine shop fastened the crank using studs rather than bolts. But now the oil pan hits the studs before sealing against the block. My question is what is the big difference using studs instead of bolts? Obviously, these studs will need to be cut down, but I'd rather just use bolts--much easier. I do know you get "truer torque readings" using studs. But this is a daily driver that I'll never race. 5,000 rpm is the max this engine will ever turn.
Take the engine back to the machine shop and tell them to reassemble the bottom end with the original hardware. There's no reason to use studs on the main bearing caps of a street driven engine. In fact, I would consider that engine suspect now. Why would a machine shop spend extra money for main bearing cap studs when assembling an engine that the owner never asked or payed for? Chances are they cut corners and used hardware store studs. Even Grade 8 studs are too weak for main bearing caps. The OE hardware was engineered correctly when the engine was built.
Yeah, you're right. I just talked with the shop. Can't switch to bolts now because the stresses are different and might affect the housing bore. I don't want to take it apart again, so I'm going to (carefully) cut down the studs.
Studs are stronger than bolts & offer more clamping force due to the fine thread on the nut side.
If they changed the fasteners, they should have line bored/honed the engine to keep everything straight... the main bore distorts from the clamping force of the bolts/studs.
If they didn't you need to take it back & get things done correctly.
The studs should be installed finger tight in the block. You can easily remove them & cut off the excess length for better clearance.
FYI, I have the studs sold by Mondello in my 442 & they clear the factory pan with no issues.
VinMichael
April 2nd, 2012 08:17 PM
