ARP main studs
Old Nov 15, 2017 | 06:50 AM
edzolz's Avatar
ARP main studs
I installed ARP main studs in my 425 Toro block and had to dimple my oil pan(non Toro) to get to sit down on the block. Anybody else used these and have this problem?
Ed
Old Nov 15, 2017 | 10:19 AM
cutlassefi's Avatar
Yes but sometimes you can run a tap into the bolt holes and screw the studs in a bit more.
And I'm guessing you had it align honed with the new studs?
Old Nov 15, 2017 | 04:18 PM
TripDeuces's Avatar
What Cutlassefi said. Tap the holes and you can get an extra 1/4 easy. I actually have mine on the shoulder but backed off a turn.
Old Nov 15, 2017 | 09:33 PM
edzolz's Avatar
This engine was rebuilt by a commercial rebuilder in 1986 and has been on the stand ever since. If it was align honed then, I do not know. I removed the crank to have it bored for a pilot bearing. Nevertheless, the reason I used the studs was, one of the main bolts has a rust ring around the top of the threads and I did not trust using it. As far as needing to be align honed now, after installing the crank and torqueing the nuts to proper setting, the crank spins without any resistance.
Old Nov 16, 2017 | 09:39 AM
VinMichael's Avatar
I just had studs installed in my block. The align hone was definitely necessary. The other thing to check are the bolt holes in the thrust bearing main cap. The main studs are bigger around than bolts so the machinist had to open up the holes slightly otherwise I wouldn’t have been able to set the thrust bearing flat on both sides. This cap needs to be able to move a little for good installation.
GATA79
Sep 22, 2017 07:20 PM
Stevec
Mar 7, 2014 04:55 PM
Al2011
Apr 18, 2013 10:49 AM
Stevec
Aug 4, 2012 06:52 PM
Al2011
Apr 19, 2012 10:56 AM
