New Engine, New Paint, New Interior...HERO camera Documented
Old Feb 12, 2012 | 03:12 PM
  #121
ah64pilot's Avatar
No worries man, when I posted the pictures I didn't realize it was on page 4 either lol! I should've reiterated that I wasn't gonna post times. I just don't feel like it does the engine or car any justice. I really just wanted to see what it would run like it is...but now I know it's definitely time for an electric pump.
Old Feb 12, 2012 | 03:28 PM
  #122
car_designer's Avatar
Great pictures, especially the burnout.
Old Mar 25, 2012 | 08:02 PM
  #123
ah64pilot's Avatar
UPDATE:
So we figured out why we had a hung idle at the racetrack, the cheapo Mr. Gasket throttle cable I had broke at the GM plastic clip right at the bracket. It made the cable kink and wasn't allowing the secondaries to open all the way. I replaced it with a Lokar cable so hopefully next trip out we'll run better (with a new fuel system).
Old Mar 25, 2012 | 08:21 PM
  #124
scooter123's Avatar
You have one beautiful ride there.......love it!!!!
Old Mar 25, 2012 | 08:22 PM
  #125
ah64pilot's Avatar
I noticed I had leaking rear wheel cylinders last week so I decided to change them. When I pulled everything apart I noticed the brake shoes were glazed over and the inside of the drums were rusting so I replaced it all. While I was at it I went on and replaced the MC...but, joesw31 talked me into converting it over to manual brakes. Since I was replacing the MC and rear WC's, I figured I MAW install a line lock so I don't ruin my newly replaced rear brakes.
New MC, brake lines, line lock, and proportioning valve:
In trying to keep the car looking stock (on the inside) I decided to hide the line lock switch under the ash tray door. My cigar lighter never gets used so I dismantled it and used the housing to secure the switch in the lighter bezel.
With the female housing on it, the switch can easily be removed and converted back.
And here's the finished product...
And that's the rest of the story...good day!
Old May 15, 2012 | 09:53 PM
  #126
ah64pilot's Avatar
I installed the electric fuel pump a month ago, I am a little late in adding pictures. For now I have a 1/2" RobbMC pickup, Holley blue pump, and am using -6 pro-lite hose to the stock 3/8" steel fuel line. It runs completely different, we'll see what it does at the track next Friday. I would've tested it sooner but I've been waiting on new rocker arms.
You can see the bracket I made that mounts to the stock fuel tank mounting points. It is a 1/8" thick 1" aluminum angle bracket.
You can see the pump is just below the lowest point of the tank. It tucks up nicely in front of the tank, just behind the axle.
Old May 16, 2012 | 10:51 AM
  #127
Nice install Steve. Only one question: Isn't that going to make changing rear shocks a real PITA? Looks like a clearance issue to one of the shock bolts.
Old May 16, 2012 | 04:24 PM
  #128
ah64pilot's Avatar
Nah, it's the angle that I took the picture at. You can hit that bolt with a 24" extension and a ratchet...I tried to think of everything when I made that bracket lol!
Old May 23, 2012 | 03:50 PM
  #129
archeryshooter's Avatar
Tony
Originally Posted by ah64pilot
Sorry to leave you hanging...I haven't been able to get on for a while. The plenum cone is bolted to the center of the intake plenum floor. It is sealed with high temp fuel resistant rtv sealer to the floor. You can get them at Mondello's. I had mine installed at the same time the intake was ported at Nickens Brothers Racing Engines here in Houston.
They are called turtles butler performance also sells them im going to add one to my intake too
Old May 28, 2012 | 03:38 PM
  #130
ah64pilot's Avatar
Ok, fuel issue is officially sorted out. For those that follow this thread, when I ran the car in February it ran a 12.73 at 104 mph. I installed an electric pump, 1/2" pickup, and regulator to the DaVinci HP 950. At the track Friday, the car ran 12.11 at 112 mph...6 10ths quicker! Now, on to suspension and gear
Here are the video's from the track for those that don't get in the performance section much:
Royal Purple Raceway 25 May 2012 Oldsmobile Beatdown
Royal Purple Raceway 25 May 2012 In-car video - 12.11 @ 112 mph
Old Jun 2, 2012 | 05:08 PM
  #131
Mochi's Avatar
Beautiful ride man! I've got to update my signature picture but I think there is a link to my gallery.
I see you have you temp/volt/pressure gauge cluster mounted under the factory radio. That's where I want to put mine but cannot find a place to send it through the firewall. Any suggestions?
Old Jun 26, 2012 | 01:01 PM
  #132
ah64pilot's Avatar
I'm sorry I didn't see this sooner...you can send it all through the firewall where the harness that goes to your battery relay is. There should be enough room, just push it through and get some more strip caulking to push back in there once your done.
What cluster did you get? I have the autogage cluster but I'm about to replace it with all Autometer Pro-Comp carbon fiber gauges.
Old Jun 26, 2012 | 03:28 PM
  #133
Mochi's Avatar
Haha no worries man I ended up drilling a hole through the firewall it helped WTH a few other things I needed to run.
I got the sunpro cluster works well. Nice ride by the way.
Old Jun 26, 2012 | 03:53 PM
  #134
FAZ442's Avatar
Really Nice Build Pilot... I had seen your car before on this site but had never seen the b4 pics. Looks like you have a really solid car.
Old Jun 26, 2012 | 05:22 PM
  #135
ah64pilot's Avatar
Thanks! Hey Faz, I should be in San Antonio in the next couple weeks...we should all get together. I'd love to see your car! lol! Two weeks ago I met up with Tom and Danny when I went for an appointment. It was a good time.
Old Sep 17, 2012 | 07:24 PM
  #136
Scott Hamel's Avatar
what do you think you will get out of her after the suspension and gears are done? 11.70s?
nice ride BTW
Old Sep 17, 2012 | 07:29 PM
  #137
ah64pilot's Avatar
I don't know what it'll run...I just finished the front suspension. I added Moroso trick springs and 90/10 shocks...however, after the last track outing where I ran a 12.11 we found a blown head gasket on the #8 cylinder so that was all fixed as well.
If I had to guess I think the car will run 11.80-11.90's right now with the fixed head gasket (and subsequent higher compression) and the trick springs. With a gear and rear suspension I think we could be in the 11.50 range conservatively...it has a 3.42 in it now so a 3.90 or 4.10 would really wake it up.
Thanks for the complements!
Old Sep 17, 2012 | 07:44 PM
  #138
add a little juice and dip into the 10.90s but then you would need a cage :O
Old Sep 17, 2012 | 07:46 PM
  #139
ah64pilot's Avatar
Haha! No thanks! 11.50's is quick enough for me...it's a street car, and I don't want to put a cage in it, not this one anyway. I'll eventually build an all out drag car but I'll find a different roller for that.
Old Sep 18, 2012 | 09:21 PM
  #140
real57vetteguy's Avatar
Re
Waayyy to nice of a car to be cutting a cage into, I wouldn't spray it either. you've spent a lot of time and money on that baby to take a risk or butcher it with a cage.
With the times your running you have one HELL of a fast street car or a great running car on the track!
Old Sep 19, 2012 | 08:39 AM
  #141
oldsguybry's Avatar
NOVICE car nut
Wow , I got a chance to go back and re-read some of the stuff I missed before ( I still got a lot more reading to do ) , and you have done a great job ! The car looks really nice , and I just love the color
Old Sep 19, 2012 | 10:55 AM
  #142
ah64pilot's Avatar
Thank you guys! I really appreciate the kind words I need to finish the interior and get wheels and tires for it but it'll have to do for now. I'm trying to finish the hard parts (rear suspension etc.) before I put more money into the interior and such.
Local Hero
May 19, 2015 07:21 PM
Local Hero
May 13, 2015 05:35 AM
redoldsman
Nov 26, 2014 08:15 AM
jensenracing77
Oct 11, 2009 04:53 PM
442_Mustang
Body work
Sep 1, 2009 06:28 AM
