My 1972 base to 442 clone / Resto (lots of pics)
Old Feb 6, 2021 | 02:14 PM
  #321
442Dude's Avatar
Hope that's what it is and nothing further is needed inside the engine.
Old Feb 7, 2021 | 06:08 AM
  #322
Brians1's Avatar
Good morning and that’s definitely what it is I got super lucky and it was just residual water left over from the first time water got in !! I put some fresh oil in and a filter primed it and I can watch clean oil coming up the pushrod now not watery at all. I also put the cardboard box from the oil filter underneath to catch the overflow and you can see it’s just clean oil - whew !!!!
Also this morning I validated the radiator is still at the same level of water that I left it out over 24 hours ago
Old Feb 7, 2021 | 08:01 AM
  #323
RetroRanger's Avatar
72 Olds CS
Good news there, hopefully thats the last bump you run into
Old Feb 14, 2021 | 08:02 AM
  #324
Brians1's Avatar
It’s alive !!!!
lots of tuning and tweaking and I’m still waiting on my Holley Hyperspark dizzy to come In.
Super happy it runs !!!
also ignore the tail pipes , the exhaust is not welded in or positioned it’s simply bolted on for noise control so the neighbors don’t get mad LOL
Old Feb 14, 2021 | 10:27 AM
  #325
scrappie's Avatar
Sounds pretty good!
Congrats!
Old Feb 14, 2021 | 11:07 AM
  #326
442Dude's Avatar
Congratulations. That's a big milestone.
Old Feb 18, 2021 | 10:24 AM
  #327
Brians1's Avatar
So I Noticed this “seeping” from the corners of the intake gasket water ports. I’m using felpro intake gaskets.
is this normal/expected ?
Old Feb 18, 2021 | 11:26 AM
  #328
dc2x4drvr's Avatar
Nope, I don’t see any sealant around the water ports..
Old Feb 18, 2021 | 12:04 PM
  #329
Brians1's Avatar
Its there both side of the gasket in fact when I did it.
Old Feb 18, 2021 | 12:50 PM
  #330
dc2x4drvr's Avatar
Well , the seeping will continue, until the leaking is fixed. I use a fairly thick coat of RTV, and trim the excess after it cures.
But, you could pickup some AC Delco stop leak tabs, they work excellent for small coolant leaks.
Old Feb 18, 2021 | 12:53 PM
  #331
Brians1's Avatar
i just ordered a set of Edlebrock gaskets. I read a review from a person who said he has pro comp heads and the Edlebrock intake and it sealed great. Those are the same heads I have so its worth a shot and I will go even heavier this time on the water ports, and again on both sides of the gasket
Old Feb 18, 2021 | 04:21 PM
  #332
dc2x4drvr's Avatar
I would try the stop leak tabs, there were installed on all GM engines off the line, good product.
Old Feb 19, 2021 | 11:12 AM
  #333
Brians1's Avatar
So these intake gaskets are just junk! glad I ordered new ones.
Old Feb 19, 2021 | 06:18 PM
  #334
dc2x4drvr's Avatar
I’ve used these Fel Pro gaskets for years, excellent sealing properties, obviously fit at the intake to head fit needs to be investigated, looks like oil? What is torque and sequence.
That gasket didn’t fail imho
Old Feb 22, 2021 | 07:21 AM
  #335
Brians1's Avatar
that was water soaked on the gasket .. ??..I blotted it with a tissue and no oil wicked on to it ?
I did 30 Ft. Lbs. in the documented sequence...
One area of suspect as I read over the weekend. I WAS using the rubber gaskets at both ends with RTV....lots have said that "raised bump" on the rubber end, there is no recess on the aluminum intake for that to fit like on the cast iron one and that could be preventing a level and flat seal?
I'm going to ditch those this time and use Right Stuff RTV on the ends and of course on and around the water ports - the Edlebrock intake gaskets arrive today.
Old Feb 22, 2021 | 08:14 AM
  #336
dc2x4drvr's Avatar
I dimple the block and intake surfaces to give the sealant a ‘grip’..Also, I use aluminum tape to build a dam on the block to hold the sealant, dry fit your intake to wag sealant thickness..installing the intake yourself is tough, a helper is good.
Old Feb 22, 2021 | 11:15 AM
  #337
Brians1's Avatar
ok so Gaskets are in...Question for the sake of asking...what side goes on the head...I assume flat side against head without the silicone beads. The silicon beads face 'up" towards intake....correct ?
** Also these instructions state to only use RTV on the ends, not the rubber ones that were also not supplied on purpose.
Old Mar 10, 2021 | 07:05 PM
  #338
Tim75's Avatar
Some call me, Tim
What an ordeal, but goodness, what a build!
Old Mar 16, 2021 | 10:20 AM
  #339
Brians1's Avatar
Hey gang...back with really good updates.
The combination of the Edlebrock intake gaskets w the "Right stuff" RTV did the trick for the intake water ports.
My Holley Hyperspark Dizzy is supposed to be here next week so I have not put the hood on yet and I'm still running the standard coil and vacuum dizzy.
Next week I'm taking it up to the muffler shop to have the exhaust properly placed and welded up.
For now here is a video of it idling around 850-900 RPM
Old Mar 16, 2021 | 12:12 PM
  #340
OLE442's Avatar
https://youtu.be/7p1GqATheaI
That is sweet. I wish my bone stock low mile 72 442 w/455 sounded that good! Where did you get the chrome valve covers.....are they notched? Thanks for sharing the video!
Old Mar 16, 2021 | 12:21 PM
  #341
Brians1's Avatar
Valve covers are from Dick Miller, straight off his website.
Old Mar 19, 2021 | 08:44 AM
  #342
lightning's Avatar
pace yourself so wife doesnt notice bank account dwindling LMAO!!
Old Mar 23, 2021 | 07:27 AM
  #343
Brians1's Avatar
Hey gang made it back from the exhaust shop last night everything is nice and tight and is fully welded end to end . She sounds great runs amazing now that the O2 sensor for the sniper unit is very happy finally
I have some tweaking here and they’re such as loose alternator belt I think I hear some of the rockers taping a little bit but I want to finish let the break in and then I’ll do those adjustments
here’s a video I took of it idling in the driveway once I got it home off the trailer
More to come
Old Mar 23, 2021 | 01:05 PM
  #344
72 Olds CS
Looks and sounds great, probably best thing you could do at this point is toss me the keys and say “have at it”
Old Mar 23, 2021 | 06:03 PM
  #345
Brians1's Avatar
hahah thank you
Old May 7, 2021 | 11:23 AM
  #346
Brians1's Avatar
hey gang back with another small but awesome update - New Glass ! I found a shop that could do my front and back glass - came out great ! They took thee extra step and painted a black perimeter around the glass to hide the epoxy they use and he even touched up the back glass channel that I didn't quite get converted to black when I did the interior color swap.
* I am also installing an OE power window setup as the next thing to do on her - Never will it be finished I guess
** and BTW - Motor is running Strong !...I did this burn out in front of my In-laws (Father-in-law requested that I light em up - a simple Yes sir and this was the result)
Old May 7, 2021 | 02:06 PM
  #347
That's certainly different. Can't do that with the rear window defog option for my car though.
Did you find a complete OEM power window setup? If yes, how are you going to fix the holes in the door cards when you pull the manual window regs and cranks? Asking for a friend
Old May 7, 2021 | 07:29 PM
  #348
Brians1's Avatar
Alan - yes, I sourced a set from a 72 via Nick Z., I posted a wanted add. I read a lot of bad reviews on the aftermarket stuff and spoke with Mattolds69 and his troubles so I snagged up OEM vs repo/aftermarket.
As far as the hole left over...I snagged these from summit
Old May 8, 2021 | 05:27 AM
  #349
Rocketbrian's Avatar
I apologize if I've missed something, but the power window switches go in the same holes as the manual window cranks. There are no holes to fill. I've put complete factory power window systems in 2 of my 71 Oldsmobiles. You just square up the holes for the switches. The perforations are indicated in the back of the door panels.
Fantastic build and documentation by the way.
Old May 8, 2021 | 05:29 AM
  #350
Brians1's Avatar
Actually you didn’t... I did !
thank you for that clarification. I hadn't researched that far yet I thought they were at a separate location but that’s even easier then
Old May 8, 2021 | 06:05 PM
  #351
babailey's Avatar
I used a special window switch that uses the original cranks in their original location as a lever/switch for the power windows on my 67 restomod.
Old May 8, 2021 | 06:35 PM
  #352
70's Power's Avatar
beautiful car!
how do you started a thread? Im trying to start one to ask for help in finding a 1970 455 aluminum intake.
Old Jul 21, 2021 | 06:17 AM
  #353
Brians1's Avatar
Hey gang...been a while but I'm back with an update. Baseball for my son has been busy, we won districts and went all the way to the semi finals for state championship, then fell short 4-5 in the13th inning !
Now that I have some down time, I did the power window swap out. I sourced an all original and working OEM setup for all 4 windows with original wiring harness and switches. Everything fit exactly as it should ! and it all works !
biggest task was taking off both doors, but the OEM dimples for where to drill was easy, used a metal hole saw and slow RPM, cut like butter.
I went ahead an sourced new water shields as well since I was in there. The switch's overlaid great where the window crank previously was - very happy how that turned out
*** I was having an overheating issue even though I have a Cold-Case Alum. Rad. with dual 12 inch electric fans. I believe I have it under control now. My mixture was off.
now have 10% of 50/50 coolant and then 90% Distilled water with 2, yes 2 bottles of water wetter. I was ruining around 218 Degrees when mixture more more like 50/50 coolant and water when hot, now hovers right at 195-198
more to come
Old Jul 21, 2021 | 08:13 AM
  #354
dc2x4drvr's Avatar
Do you have a door dolly?
Old Jul 21, 2021 | 08:19 AM
  #355
Brians1's Avatar
My Father-in-law came over and helped me remove the door. I have a body stand I purchased from Summit a while ago, did great to support the door (Interior side down) and made easy work of it to drill the door and pillar.
steedaq
Nov 10, 2023 10:43 AM
Barbara Casteel
Sep 1, 2018 10:43 AM
gearheads78
Dec 7, 2017 07:16 PM
Beamin23
Sep 14, 2017 10:27 PM
Big Henry
Aug 23, 2011 09:27 AM
