69 Cutlass S convertible steering box change
Old Jul 25, 2021 | 07:46 AM
lala5818's Avatar
Whats the most cost efficient and simplest way to change the power steering box ratio in my gear box? I've got the standard one now. i'd like to make the steering a little quicker. Is there another steering box i can buy that will bolt on with little changes to install?
Old Jul 25, 2021 | 10:48 AM
4speed455's Avatar
You can buy new Lares boxes from rock auto or other vendors. I went with the 93-97 Jeep Grand Cherokee box from a junkyard. The JGC box you gives you the largest torsion bar you can get that comes with the full turn radius that is correct for our cars. You can get boxes that have larger torsion bars from other cars but you will lose some of your turn radius. The swap does require a new coupler and adapters to use your stock lines. All in it cost me under a $100 and took me one afternoon.
Old Jul 25, 2021 | 10:51 AM
4speed455's Avatar
Here is the write up I did over on ROP
https://www.tapatalk.com/groups/real...ody-t1558.html
Old Jul 25, 2021 | 11:10 AM
Rebuilt Saginaw 800s are available in quick ratios from a variety of sources and are probably your easiest solution. Conversely, if originality is a concern, your existing box can be rebuilt with a quicker ratio.
Old Jul 25, 2021 | 07:47 PM
truckman5000's Avatar
W30
I did the pci ( spelling idk) from summit
new hoses, hotchis shocks. Umi 1in lowering coils.
New actually everything...
Drives like a new car.
I researched the jeep box....200$ more....I did the bolt on one. The jeep you need metric x sne hoses
Old Jul 25, 2021 | 07:57 PM
tkcutlass's Avatar
Another post on the subject
I got a rebuilt one from Hector at carhex see above post.
Old Jul 28, 2021 | 02:26 PM
69455's Avatar
Tight ratio gear box for sale
$100 + shipping
Northern IL
TommyTheCat
Jun 29, 2020 11:02 AM
Natedawg
Suspension & Handling
Mar 27, 2020 09:11 PM
Fazer
Feb 22, 2020 10:07 AM
agtw31
15
Jun 14, 2010 06:01 AM
craftsmen22
Mar 19, 2008 09:54 PM
