Motor swap need advice asap ?
Old Jun 22, 2018 | 06:53 PM
Mark Mccrystal's Avatar
I got a 350 rocket out of a 76 cutlass its carbarated and I'm trying to put it in a 1985 442 its fuel injected and I'm wondering if I need to switch the computer and ECU
Old Jun 25, 2018 | 06:11 AM
Mark, sorry you didn't get a reply earlier. If you use the engine from the 76 Cutlass it will swap into your 85 442 without any problems. Just make sure you use the distributor and carburetor from the 76 Cutlass.
Old Jun 25, 2018 | 07:54 AM
rccktmn2's Avatar
The 350 will swap in without any issues, brackets, accessories, exhaust, trans will all bolt up with no problems. As stated above use the distributor and carb from the 350 the carb and distributor are computer controlled on the 85 so you either use the non computer controlled carb and dist or you use the computer controlled carb and dist but you can't mix and match it's either all or nothing.
My question is how is our 85 442 fuel injected?
Skribble93
Jun 9, 2022 03:21 AM
Mark Mccrystal
Jun 23, 2018 08:47 AM
Jonathanpolo92
Non-Olds Engines
Mar 1, 2018 04:44 PM
Amarion58
Feb 23, 2017 11:16 AM
Jokster24
Jul 1, 2014 04:55 PM
