And Here we go...
Finally in Colour
Well another milestone day...in colour and I am pleased with it. I did a pretty good job getting this thing straight for a rookie. I did not lay the color. The painter just laid the color and clear on.
It is not cut and buffed yet....will wait awhile for that. Not sure if I am brave enough for that myself yet.
Now lets see if I can get this together without scratching the hell out of this.
haha..with no seats the rope was my safety net.
I am going to a gray rim color..keeping the same tires I just have to scuff them back to life. I would like to have 15" of the same style but have to wear these out first....or try and sell them
getting there
picking at the grills and trim. Can't seem to locate my headlight adjustment screws....I know I have them.
Switching gears a little< i just recased my rear seat bottom..pic to follow.
Did anyone ever use that roof material from home depot. I seen it on u tube and it is a hell of a lot cheaper than dynamat.
Scott
B-Quiet vs. DynaMat
Hey guys:
Here is an alternative to DynaMat that's about 30% cheaper. It works on the same physical principles as DynaMat, (constrained layer damping) and it comes in two thicknesses, 45 mil and 60 mil. Follow the link to check it out.
http://www.b-quiet.com/compare.html
Rodney
Rodney
[QUOTE=cdrod;737962]Hey guys:
Rodney[/QUOTE
Thanks....I'll check it out . any of this stuff is heavy and shipping is bad here
Rodney[/QUOTE
rear seat
mixed emotions here..
back seat bottom I recased and it looks great. The upper section I did not do and am not sure if I want to try and put on a new cover. It is in good shape and pretty close to the new color. I am afraid if I take the cover off the cotton will fall apart.
I did the front seat before the overhaul...very first thing I did when I brought it.
tips for installing drip rail mouldings
does anyone have a link or can you provide some tips on how to put on drip rail mouldings.
I picked up a good used set and I dont want to damage them. Whoever put mine on before damaged the hell ut of them.
Mustang Drip Rail Molding Installation - YouTube
This should help.
Thanks....unlike the guy in the pic I have bc/cc on the rails now. I was thinking I will have to sand the clear down,
Scott
This should help.
Scott
got the trim on the drip rails...with an extra set of hands. Only one small dent.
Its been that long since I took out the rear quarter glass....i cant seem to get it to go back in. as it interfers with the top. Any suggestions ?
new weatherstripping on doors.
doors and weatherstripping
installed new weatherstripping on the doors...now they dont close right/align with quarter....with this get better with time. Without it the close/align fine.
Should mention that I uses glue on the doors as well....the kit was from steel rubber. Not sure if I was supposed to ?
These are not the doors that came off the car...are there any adjustments on the doors ? ..besides moving the striker.
There are only some parts of the door seal that are supposed to be glued with the 3M butyl. The rest of it should have plastic pins that locate the rubber on the sheet metal.
The rubber seems to be 'leaning in' too much compared to mine which is OEM. Yes, you can adjust the door outward at the front hinge plates by loosening those 3 bolts that attach the door to the hinge. Just make sure you have someone helping you and there's some support under the door. It's buggerishly heavy as you probably know. If your sheet metal already is lined up properly, this isn't the time to start re-aligning it. The door should close firmly with the rubber installed. It should close very easily with the window down, but a bit of a slam with the window up.
Test Drive.- hard to start when hot
Not should I put this in the engine forum or not...Took the car for the first test drive tonight..and it needs some work.
Sounded good....but when engine got hot it was hard to start...would not start until cooled. I don't have a heat shield on the starter but I do have the one from the 350.
Also...for a freshly rebuilt 455 .....the old 350 had what seemed like more pep. May call in a fried to check the setup/ timing.
What should the oil pressure be when the engine is hot?
i liked it when it idled a bit choppy but it did not have the power.
Spoke to a guy I know and he said I probably have too much vacuum on the holly...it will be a month before he can look at it. may have to figure this one out on here
