gasket problems
Old March 28th, 2013, 06:23 PM
spyke's Avatar
gasket problems
hey i just took my trans mission out of my 70 cutlass with a 350 rocket in i had been changing the pan gasket thinking that maybe it was to tight or to loose, then i came to find that the front seal on the trans was leaking.So i pulled the trans and replaced the front and rear seals, now since the trans is still out of the car i want to change the oil pan gasket because it also has a leak i need a lil direction on how to gett this oil pan off without pulling the motor out of the car? i was told that it would be hard because of the flywheel soim wondering if i need to remove the flywheel to make it easier and not have to lift the motor.
spyke is offline
Old March 28th, 2013, 06:34 PM
Oldsmaniac's Avatar
You will need to jack engine up off the mounts to clear engine cradle/frame section with the pan. Hopefully you have dual exhaust else crossover pipe must come off.. PITA!
Oldsmaniac is offline
Old March 28th, 2013, 08:13 PM
spyke's Avatar
yeah i do have dual exhaust so where to jack it up at? wont it mess something up if i put the jack under the harmonic balancer?
spyke is offline
chasman414
June 25th, 2020 07:05 AM
aussiemobile
February 15th, 2013 07:31 AM
harry k
November 21st, 2012 08:54 AM
dallasite21
June 20th, 2010 05:37 AM
Sixoh
August 8th, 2006 05:11 AM
Quick Reply: gasket problems
