Front coil replacements
I just received my new coil springs from rock auto today and noticed they are not flat on the top like the originals . Will I need insulators for the tops so they sit flat ? There were no insulators top or bottom on the originals.thanks .ps this is for 1972 cutlass supreme convertible
ok i went out to the garage and took the pic. they are moog 5382 they are about a half inch shorter in overall hieght .i did locate the white paint spot on them which would indicate the top of the spring(if what ive read is correct).notice the original is quite flat at the end of the coil .not sure if it makes a difference when seating the new coil
Some info I archived yeas ago from the Moog coil spring catalog shows those are the correct springs:
MOOG #5382
72 with A/C and 350 4bbl
free height = 16.724"
load height = 11.000"
load = 2066 pounds
load rate per inch = 360 pounds
MOOG #5382
load = 2066 pounds
i guess theyre just made differently. so the important thing would be seat the spring in the lower control arm pocket properly and the top is what it is ?thanks for looking up the numbers for me 71
Scott Hamel
September 12th, 2012 04:18 PM
