Disc brake conversion issue w/power booster fitting
Old December 7th, 2013, 08:25 PM
W-27's Avatar
I have a 68 442 that I am converting from front drum brakes to front power disc brakes. There is a fitting on the intake that needs to be male 3/8"-27 with a 90degree elbow and a female 1/2"-20 in order to fit the vacuum tubing that goes to the booster. Apparently nobody makes one so I am wondering how the original 68 vacuum tubing was made or connected or what can I do to connect mine. Any help is appreciated.
W-27 is offline
Old December 7th, 2013, 09:39 PM
oldspackrat's Avatar
Get us a picture of what you need? I'm sure someone here can hook you up.
oldspackrat is offline
Old December 8th, 2013, 05:01 AM
Old School Olds
tru-blue 442's Avatar
Not sure if this will help or not.
I built this engine for my 69. It is
a 455 with a 398662-D2 intake.
I think the elbow you need is the one
with the tube that goes to the booster
on the back of the intake, correct?
tru-blue 442 is online now
Old December 8th, 2013, 11:28 PM
W-27's Avatar
Exactly but.....
You are absolutely correct but the elbow must have a male 3/8"-27 (bottom) and female 1/2"-20 (top) and apparently the 69 models are different (but I never measured a 69 elbow and I don't have one) if any one as the elbow like in the picture with those measurements I would love to buy it or trade for it. If you can just measure that one it would be a great help to me.
W-27 is offline
Old December 9th, 2013, 12:42 PM
Old School Olds
Here are pics of what I found.
The small one on the left is from a 69, D-2 intake.
The larger on on the right is from I don't know.
They both have the same male end, 5/16 I believe
to fit into the intake. The larger one one I think will
accept the 3/8 line or tube.
My camara hates close-ups.
Old December 9th, 2013, 08:16 PM
Old School Olds
Louis, got your e-mail, will send a pm.
Old December 10th, 2013, 10:25 AM
DLaz70OLDS98's Avatar
Inline Tube sells the entire set up. It is part # INL10103 and goes for $32. You can also look in McMaster Carr and see if they have thoes fittings.
DLaz70OLDS98 is offline
Mocephus
October 1st, 2021 09:45 AM
defiant1
Brakes/Hydraulic Systems
March 22nd, 2015 07:05 PM
babs68
September 11th, 2014 03:16 PM
1956olds88post
August 22nd, 2013 06:33 PM
Maverick
June 26th, 2013 08:21 AM
Quick Reply: Disc brake conversion issue w/power booster fitting
