Convert to a stick
Old April 9th, 2014, 05:15 AM
Smash
smash72's Avatar
Convert to a stick
72 Cutlass resto, would love to convert to a stick. Any major advantage doing it now with the 455 pulled ? Also a ballpark price of what that might cost me if I could find a good rebuilt trans. One last ques is there anything I should do different to this motor while rebuilding it in preparation for a stick down the road. Right now I'm dialing down a racing motor to a driver. Manifold , carb , cam, lifters, elect ign, toque converter etc. I'm a little green around the Motörhead gills so any input is helpful input. Thx in advance.
smash72 is offline
Old April 9th, 2014, 05:16 AM
Smash
smash72's Avatar
Forgot to mention it is currently a column shift.
smash72 is offline
Old April 9th, 2014, 06:30 AM
66400's Avatar
Crankshaft will need to be machined for the pilot shaft bushing.
Henry
66400 is offline
Old April 9th, 2014, 06:46 AM
Run to Rund's Avatar
A lot of this has been discussed before on this forum. Do some searches with key words and you will get a lot of information. Two big advantages to doing the swap now are crank machining for the pilot bearing, as noted above, and the ease of using offset dowels to align the bellhousing perfectly.
Run to Rund is offline
Old April 9th, 2014, 08:23 PM
Smash
smash72's Avatar
Good tip, sorry to go down an old road, beat a dead horse, hit a empty bong, etc. only been up a week. I still get jacked by all the work ahead. I'll snap out of it soon enough.
smash72 is offline
Old April 9th, 2014, 08:43 PM
Mr Nick's Avatar
What kind of manual transmission? A factory 4-speed, or aftermarket 5/6-speed?
Mr Nick is offline
Old April 10th, 2014, 08:40 AM
Smash
smash72's Avatar
Going over the motor build specs tonight so will let u know. I would say closer to factory since I'm dialing down the motor to make it a driver.
smash72 is offline
illumined
Suspension & Handling
January 19th, 2015 11:16 AM
vistacruiser1971
November 9th, 2013 01:19 PM
leslie
Ninety-Eight
September 17th, 2007 06:17 PM
Kennybill
May 10th, 2007 12:52 PM
Kennybill
July 19th, 2006 03:34 AM
Quick Reply: Convert to a stick
