Convert to a stick
Convert to a stick
72 Cutlass resto, would love to convert to a stick. Any major advantage doing it now with the 455 pulled ? Also a ballpark price of what that might cost me if I could find a good rebuilt trans. One last ques is there anything I should do different to this motor while rebuilding it in preparation for a stick down the road. Right now I'm dialing down a racing motor to a driver. Manifold , carb , cam, lifters, elect ign, toque converter etc. I'm a little green around the Motörhead gills so any input is helpful input. Thx in advance.
A lot of this has been discussed before on this forum. Do some searches with key words and you will get a lot of information. Two big advantages to doing the swap now are crank machining for the pilot bearing, as noted above, and the ease of using offset dowels to align the bellhousing perfectly.
illumined
Suspension & Handling
January 19th, 2015 11:16 AM
vistacruiser1971
November 9th, 2013 01:19 PM
