can some1 please tell me what this is?!
Old Jan 20, 2013 | 07:06 PM
79Cutlass805's Avatar
This is my transmission that is going behind my stock 307. From what I know it is a Th2004R. It came out of a '84 delta 88. I see it has these wires and connecter. WHAT IS IT? And will it work in my non computerized '79 cutlass supreme? Please help
Old Jan 20, 2013 | 08:55 PM
henryk8398's Avatar
Hangin' out...
It could be a 200-4r, but judging by how short the pan is in the second photo, I think you have a TH350c. Is the transmission pan square with one corner cut off?
The connector on the side is to control torque converter lock-up. When locked, engine speed drops around 200-300 RPM. The computer controls the lock-up. There are aftermarket kits to control it. The diesel cars have a non-computer method of controlling lock-up, too. Lot's of people run the transmission without the lock-up connected. Some say that can cause damage due to increased heat. I don't see how 200 rpm would make much of a difference.
Ultimately, if you are putting a computer controlled trans into a non-computer application, you might need to install a bracket on your carb to control the TV cable. Some mistakenly refer to it as a kickdown cable, but it does much more than that for transmissions like the 200-4r. If the geometry and adjustment are not right, you will cook the trans in very short order!
Have a gander...
http://www.classictrucks.com/tech/03...l/viewall.html
Old Jan 20, 2013 | 10:08 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
definitely not a 2004r.
2004r would have a dual bolt pattern 1 piece case.
Old Jan 20, 2013 | 10:10 PM
Looks like a 200c to me.
Old Jan 21, 2013 | 03:08 AM
rob1960's Avatar
I agree 200c the 350c has a bolt on tail shaft
Old Jan 21, 2013 | 05:09 PM
what if i dont connect them? shouldnt it work anyway since it ran by vacume?
Old Jan 22, 2013 | 07:34 AM
rob1960's Avatar
If it is a 200c it won't have a vacuum modulator on it just like the 200-4r. It uses a TV cable like Henryk said. You might want to talk to a reputable trans shop in your area,or search online for a shop that does hi-perf builds. I'm sure someone has some kind of switch you can hook up so you can use the lock up feature manually. They put the 200-4r in allot of non-computer controlled musclecars for the overdrive and they, just like your 200c, had provisions for lock-up converters.
Old Jan 24, 2013 | 10:21 AM
i got a new trans. i got a th350
Caveman-455
May 10, 2012 09:21 AM
krissiibabii
Aug 24, 2010 04:42 AM
sx455raidercelticfan
Jun 21, 2010 09:28 AM
mscofer
Apr 4, 2010 06:35 PM
J-(Chicago)
Feb 13, 2008 03:29 PM
