Addiction Relapse Again, 67 442
Old Feb 7, 2021 | 11:57 AM
  #161
Oldsmaniac's Avatar
That's a nice color. Mine calls for antique pewter, so I get to go the color JB Weld.
Many years ago there was for sale a 67 442 Antique Pewter with red interior and 4spd with console, I am still drooling over that car!
Old Mar 9, 2021 | 03:08 PM
  #162
Oldsmaniac's Avatar
The rear seat was taken to the upholstery guy right down the road from me to have the PUI covers put on. This job I am sure I could do myself but decided not to risk the possible aggravation and me possibly trying to fit a seat cover that was made wrong! Yes I had a PUI seat cover sewn wrong on the Track Pack and my buddy had a Legendary seat cover with misaligning seams... Well I picked that up today and left 1 bucket there for recover... trying to ease the pain $. I also lit fire to the 400 and let it run for a good 20 minutes at 2800 rpm. Oil pressure was good as well as water temp. Next time will give it another 15 minute run and that should be it as far as break-in goes. Then I can fine tune curb idle, check timing and dwell again.
Old Mar 9, 2021 | 04:41 PM
  #163
67abody's Avatar
Here are a few more pictures of those exhaust tips... I got the repro Z bar.... well if you look at the picture below you will see the 1st one is the new one, the gray one I believe possibly the correct factory one for a 67 and the other one a 68 up. The repro does not have the bushing like factory ones at the top hole. And the hole needed to be opened up a bit for the rod to go thru.... Ok its mounted and will work fine. A slighter angle is still there from the pushrod to the fork but I believe it will be ok. Thanks all for your comments!
  #164
CRUZN 66's Avatar
Olds Fever
Great looking rear trunk seat... Nice job, must have stung the pocket just a little...
Old Mar 9, 2021 | 04:43 PM
  #165
67abody's Avatar
Joe, very impressive on the tips. You have a really good skill set, I’m reminded of It every time I open the garage 😉
Old Mar 9, 2021 | 04:45 PM
  #166
Oldsmaniac's Avatar
With every car I do, there is a price increase at all ends, such is life!
Old Mar 9, 2021 | 04:49 PM
  #167
Oldsmaniac's Avatar
I thank you for that!
Old Mar 9, 2021 | 05:29 PM
  #168
Oldsmaniac's Avatar
A short video of the 1st start today....all seems well...so far.
File Type: mov
Old Mar 9, 2021 | 05:36 PM
  #169
6D7 442's Avatar
Looks and sounds great! You’re moving right along.
Old Mar 9, 2021 | 08:55 PM
  #170
I've never seen a rumble seat in an A body before. Looks good.
Old Mar 10, 2021 | 07:32 AM
  #171
Oldsmaniac's Avatar
Rare Option, didn't you know? LOL
Old Mar 14, 2021 | 05:41 PM
  #172
Oldsmaniac's Avatar
I ran the 400 for another 15 minutes at around 2800 rpm and was hearing a tapping sound. I checked a lot of things and thought maybe the balancer was making the noise since when installed it slid all the way on by hand.... Well I tightened the motor mount bolts, checked rocker arm motion, checked plugs, and remembered I had a noisy distributer laying around which I probably installed in the 400. Seems though the balancer was not the source of the noise. So there is more to do here with the 400 but my plan is to continue with the painting and get the car roadworthy for a real roadtest. I am doing little things on the interior that can be done before paint. I installed the PUI rear side panels and need to start fitting the door panels.
Old Mar 14, 2021 | 07:35 PM
  #173
6D7 442's Avatar
Good to hear that it’s not the balancer.
Old Mar 16, 2021 | 07:28 AM
  #174
Oldsmaniac's Avatar
Thanks but I was hoping it was and I would swap it out and all will be well, but now there is still a mystery.
Old Mar 25, 2021 | 06:06 PM
  #175
Oldsmaniac's Avatar
The buckets are finished and I bolted in the driver's side for drivability. I found the mechanical oil gauge inside the car was dripping oil so had to redo that and also found some antifreeze on the front floor pan. This should not be because I replaced the heater core with one that came with another project. It looked new. I will test it but in the mean time I bought another one. 2 gallons of pewter lacquer have been ordered now I just need some better warmer weather for spraying outside.
Old Mar 25, 2021 | 08:57 PM
  #176
Mr Gadgets's Avatar
Looking Great!!
Old Mar 25, 2021 | 09:18 PM
  #177
6D7 442's Avatar
Nice. Did you figure out the tapping sound? Was it the distributor?
Old Mar 26, 2021 | 05:05 AM
  #178
Oldsmaniac's Avatar
More evaluation is necessary, will continue with primer and paint and leave the engine issue for a while. I think it really needs a road test for proper diagnostics....
Old Mar 26, 2021 | 06:39 AM
  #179
CRUZN 66's Avatar
Olds Fever
Seat looks great... You must be getting anxious to complete the rest of the interior...
Old Mar 26, 2021 | 11:23 AM
  #180
Oldsmaniac's Avatar
Thanks all for the comments! Every piece that goes on is always exciting to me, must be why I also enjoy working jigsaw puzzles.
Old Apr 1, 2021 | 01:14 PM
  #181
Oldsmaniac's Avatar
Made some progress on the interior, carpet done, both buckets and the problematic non console shifter boot. Man these always fight me getting the screws thru the rubber and into the holes in the floor.
Old Apr 2, 2021 | 05:57 PM
  #182
6D7 442's Avatar
The new upholstery looks great!
Old May 14, 2021 | 05:58 PM
  #183
Oldsmaniac's Avatar
Its been a while since I posted an update. I had to do some work on my house and garage before they imploded. The Spring weather also has been cool and damp. The noise I was hearing in the engine has seemed to have gone away. I found the motor mount thru bolts loose and tightened them. I am hoping that is all it was. Today I drove the car out of the shop, bled the brakes and wet sanding the primer on the body. The 1st drive of a car purchased DOA is quite exciting!
I did some masking and hopefully tomorrow I can continue with the primer.
Old May 14, 2021 | 08:27 PM
  #184
6D7 442's Avatar
Looks good, you’re moving right along.
Old May 15, 2021 | 04:33 PM
  #185
CRUZN 66's Avatar
Olds Fever
You are starting to get me motivated to start the restore on my 67-W30...
Old May 15, 2021 | 04:52 PM
  #186
Oldsmaniac's Avatar
Love That! What do they say... Time and Tide waits for no man?.... Better get to it, time is sailing by...
Old Jun 6, 2021 | 05:15 PM
  #187
Oldsmaniac's Avatar
Today the weather cooperated and I was able to get 2 coats on paint on the 442. It was hot so I needed to find some shade but luckily the humidity was not bad. So far so good I would say. I like he color a lot but it doesn't pop like the red did, gold on the wagon, white on the TC.
Old Jun 6, 2021 | 08:38 PM
  #188
6D7 442's Avatar
Getting closer and closer to being done!!
Old Jun 7, 2021 | 04:01 PM
  #189
CRUZN 66's Avatar
Olds Fever
Looking good... My motivational point is rising... LOL
Old Jun 8, 2021 | 04:16 AM
  #190
Oldsmaniac's Avatar
Thanks guys for the support, seems like this project is more work than they used to be...LOL Now if the weather gets right I can continue, nothing good forecast till the weekend. and then I need to do the fenders, hood trunk lid....not over the hurdle yet.
Old Jun 11, 2021 | 07:15 AM
  #191
Bernhard's Avatar
Nice! IMO no color highlights body lines like silver in conjunction with the lacquer paint.
Old Jun 18, 2021 | 06:31 PM
  #192
Oldsmaniac's Avatar
Ok lets try this post again.... Weather has been great the last 2 days for painting. The hood, body, and trunk lid have 3 coats of color on them. The fenders will be next. I am keeping track of paint usage and I should have enough for 5 coats of color on all with a bit left over. I am working on the 1st gallon still and expect to have a least a couple of coats on the fenders before I need to open the second gallon. Progress feels good!
Old Jul 15, 2021 | 02:17 PM
  #193
Oldsmaniac's Avatar
Slowly progress is being made, I am at the stage of sanding and buffing however something didn't go quite right while laying down the paint. I started sanding and buffing the fenders. There are some spots that are kinda blotchy with possibly a bit more metallic than others or perhaps a slightly darker area. The process was done as before and although this is my 3rd metallic lacquer job I have not experienced this issue. As before I initially open the 2 gallons of paint, empty into a larger container, mix well and then refill the original cans. I stir well for mixing and thinner dilution and before each paint cup fill. Perhaps silver is trickier to spray, don't know. So this is a bit of a disappointment, only noticeable upon close inspection, and so far only on the one fender. I have found a lighter sand with the 800, 1000, and 1500 before buffing reduces/eliminates my issue with the paint so that is what I will do. I think the final product will be ok overall, am putting together a driver car and not a show piece anyway... and I am my own worst critic.
Old Jul 15, 2021 | 02:21 PM
  #194
6D7 442's Avatar
Looking good!!
Old Jul 15, 2021 | 08:22 PM
  #195
Joe - I haven't looked at your progress in awhile and I'm catching up. You have serious skills man! I am envious! Your new seat covers look fantastic! I have a question about the style of the seat covers though, and I'm sure you'll know the answer. When I bought my '67 4-4-2 I was told the seat covers were actually original to the car. They looked too new for it to be true, but I just went with it because the entire car was so nice and I didn't care if they were repro's. In any case, the pleating on my covers are parallel to the dash, and your new ones have pleats perpendicular to the dash. Just wondering if you can tell me if mine look OEM correct, or should they look like yours? I've included a couple pics when you have time to respond. Please forgive me for hijacking your thread a little, but your beautiful new covers got me thinking, and that's a dangerous thing.
I'm excited to keep reading on in the thread and see how far you've gotten. Keep up the great work, your gonna have a real beauty!!!
Old Jul 15, 2021 | 08:37 PM
  #196
Joe - I finished catching up, and I absolutely love that color, just stunning!
Old Jul 16, 2021 | 03:56 AM
  #197
Oldsmaniac's Avatar
Thanks! As for seat covers my car is a Supreme post car or Sport Coupe. They used a different pattern seat cover than the Supreme non post cars. Yours are correct if you don't have a post car. The plain Cutlass, non Supreme cars also used the seat cover pattern as the Supreme Sports Coupes.
Old Jul 16, 2021 | 04:32 AM
  #198
Joe - Thanks for the response. Well that explains it perfectly, mine is a Holiday Coupe. I do find it odd though that they used different seat cover patterns on the Supreme Holiday Coupe vs. Supreme Sports Coupe. I can easily understand a difference between the F-85 and Base Cutlass covers from those on the Supremes, but a difference between sub-models within the Supreme model line just seems odd. I think I actually like the pattern on your car better!
I'm really glad your odd motor knock/tapping seems to have disappeared. Also very glad you have found an application technique to alleviate the color matching issue you had on the fenders. Like you said, you may be your own worst critic, because the pics look fantastic! I can't wait to see the finished car. Man I sure do love the '67's, and a 4-speed Sport Coupe to boot, it's gonna be a real gem!
Old Jul 16, 2021 | 04:58 AM
  #199
Oldsmaniac's Avatar
I cant explain it either, the 2 different seat patterns for a Supreme. I cant say which one I prefer... This is my second Post 442, somehow they find me I guess.... the last one was a one belter, power nothing and bench seat 4spd, this one has the buckets and only power steering and was a radio delete car....
Old Jul 16, 2021 | 05:12 AM
  #200
Cool combo's on both cars. My 442 is a little odd too, or most casual observers think it is, TH400 with shift on the tree and strato buckets. Always a topic of discussion at cruise-ins or shows, especially with folks who don't know Oldsmobiles and what did/didn't come with various options/packages.
