70 cutlass supreme convertible my first frame off
Old February 20th, 2022, 03:28 PM
  #241
tkcutlass's Avatar
Originally Posted by Phoenix8990
I may have missed it in the past but what color are you going to paint it?
Steve
I was having trouble deciding, so I let the body tag decide it 19 Ebony Black.
I may be brave or stupid.
So it's gonna be triple black. with minimal trim. ( gonna leave off the supreme side rust-catching trim).
tkcutlass is offline
Old February 20th, 2022, 03:29 PM
  #242
tkcutlass's Avatar
Originally Posted by Eddie Hansen
Looking good man real good
Thanks, I appreciate the comments
Old February 21st, 2022, 09:55 PM
  #243
tkcutlass's Avatar
Blasted, primed, and rebuilt the door hinges.
Old February 22nd, 2022, 05:19 AM
  #244
oldsconv's Avatar
Looks great. My 70 SX Convertible had similar repairs needed (trunk, floors, quarters, etc.). It looks like the newer body you used is from an A/C car if I read the firewall shapes correctly. Are you going to add A/C to this one?.
oldsconv is offline
Old February 22nd, 2022, 07:18 AM
  #245
tkcutlass's Avatar
Thanks!
Yes, I have acquired most of the parts to add A/C.
With luck, it will have power windows, power locks, power trunk release, and since there is a hole in the quarter panel even a power antenna.
Old February 22nd, 2022, 10:19 AM
  #246
tkcutlass's Avatar
Got a nice surprise I didn't have a ship date on my exhaust and it just showed up.
Pypes Performance Exhaust SGA42 - Pypes H-Bomb Exhaust Systems
Old February 24th, 2022, 08:17 PM
  #247
tkcutlass's Avatar
Got the pypes mostly installed
Old February 25th, 2022, 04:40 PM
  #248
tkcutlass's Avatar
Got another surprise.
The engine is on the dyno.
Standard rebuild nothing special for my convertible.
Old February 26th, 2022, 08:09 PM
  #249
tkcutlass's Avatar
Prepping for the engine got the exhaust pretty much settled, need to see where the headers line up.
Old March 6th, 2022, 06:23 PM
  #250
tkcutlass's Avatar
Seeing a couple of recent posts regarding steering columns I figured now would be a good time as any to see what I could do with my steering column.
Blasted, but plenty of pits. good thing most of it will be hidden.
Old March 6th, 2022, 07:32 PM
  #251
Eddie Hansen's Avatar
Moving along nicely!!
Your moving along now ! Very nice work
Eddie Hansen is offline
Old March 9th, 2022, 10:23 PM
  #252
tkcutlass's Avatar
Picked up the driveshaft from CT Driveshaft.
New Joints balanced and primed.
High perf joints without grease fitting? sound right?
Gave it a quick coat of chassis black.
Old March 10th, 2022, 02:55 AM
  #253
Rodney
cdrod's Avatar
Tim:
I love that you post so many pics of your work and progress. It has been really helpful to me to see your pics when trying to work out parts installation or placement questions; the steering column teardown being your latest mega picture post! I can't tell from your pics, is your newly balanced driveshaft a single, solid tube or do you have the 2-piece style with the rubber insert? I have the factory 2-piece style but thinking it might be best to have a new driveshaft built from a single solid tube to eliminate the 50-year old rubber insert. Any thoughts on this?
Rodney
cdrod is offline
Old March 10th, 2022, 08:12 AM
  #254
tkcutlass's Avatar
Thanks, Rodney
I was thinking I post too many pics, there are actually many more.
I try to take pics as I disassemble mainly so I can remember how to put things back together.
Here are the before pics of the one-piece driveshaft.
From what I read the two-piece driveshaft are for lower HP AT applications.
Old March 12th, 2022, 08:13 AM
  #255
Too many pics?
Too many pics? Blasphemy my friend lol!!!!! Love the details keep ‘em coming
Old March 15th, 2022, 09:07 PM
  #256
tkcutlass's Avatar
Picked up the engine today,
Flexplate needs blasting with luck tomorrow I'll have time to take care of that mate the tranny and get the engine mounted.
Any tips? thinking this part should be pretty straightforward.
the engine was tested, is rusty water normal after a rebuild, or is that normally flushed out better?
Old March 16th, 2022, 06:12 AM
  #257
Mr Gadgets's Avatar
If you plan to install headers and install in the frame with the stock starter, you will find, as I did 40yrs later, I had to cut the starter to get it out. Solution is to install a mini starter. I had Hooker street headers and there is no way to get it out even with the header unbolted.. Just an FYI.
Mr Gadgets is offline
Old March 16th, 2022, 07:05 AM
  #258
Rusty water
I would think that would depend on what you had done to the engine, if it included a full boil etc I would think there wouldn’t be rust, that said it is hard to see how much rust is there. Maybe if they ran the motor they used plain water? That would produce some surface rust pretty quick?
when I picked my motor up it was just some green antifreeze that came out , I’d flush it after install and talk to your shop
Old March 16th, 2022, 04:50 PM
  #259
tkcutlass's Avatar
Good progress, got the flex plate blasted and primed.
Torque converter installed transmission mated to the engine and onto the frame.
Old March 17th, 2022, 06:10 PM
  #260
tkcutlass's Avatar
Got the headers installed had to remove the oil filter and lift the engine for the passenger side.
Tight fit with the body off must be a real challenge when everything is in place.
Thinking the exhaust needs to be moved back a few inches for better clearance with a straight pipe going under the two humps in the cross member.
Old March 17th, 2022, 06:29 PM
  #261
Loaded68W34's Avatar
You may want to bring the x pipe back a little bit (shorten straight portion going into mufflers) to get the exhaust up closer to the cross member and gain more ground clearance. Project is looking great by the way.
Loaded68W34 is offline
Old March 17th, 2022, 06:38 PM
  #262
tkcutlass's Avatar
Thanks, Yes I am thinking it should go back a few inches that way the pipe goes through the center of the hump.
Not looking forward to refitting the pipes to the mufflers though, even with a flaring tool I had trouble getting the pipes deep enough into the mufflers.
Old March 18th, 2022, 08:25 AM
  #263
X2
Work now will be a lot better than trying to adjust after the bodies on , the pipes will move some with vibration and you won’t like rattles at idle etc , I agree work looks great !!!
Old March 18th, 2022, 09:31 PM
  #264
tkcutlass's Avatar
Thanks, Eddie, Loaded I appreciate the encouragement.
After a few iterations, I ended up moving the H-pipe back 6 inches.
I have pretty good clearance now.
The headers are not exactly parallel to the frame, Is it normal for the front pipe collectors reducers to be on an angle?
Is it normal to have so many connections/clamps?
Old March 18th, 2022, 10:07 PM
  #265
Looks good. The angle going into the headers is why they use a ball flange and not a slip joint or triangular flange so it is fine. If you do not like the number of clamps, You can weld all of the joints together once you are happy with the final position. I would do this after the body is on and you are sure of the fit. Then put a few good tack welds on the joint and pull the pipe down to do a full perimeter weld around the joint on the bench/ floor. You will not need a TIG because stainless actually welds really nice with a regular MIG. The welds will rust if left exposed though unlike using a TIG with stainless filler. I used a mig for my vista exhaust and just polished the welds when I was done. I used a generic kit with four 4' 2.5" straight sections, four 2.5" mandrel bent 90's, four "U" bends, four 45's, and a 2.5" X pipe along with a pair of magnaflow mufflers and some custom mounts. There should still be enough left over to build a system for the 67 camaro convertible I have been building for my dad. The Vista system really only uses 4 band clamps (techically 6 but 2 hold the collector reducers to the headers).
Old March 18th, 2022, 10:44 PM
  #266
Rodney
cdrod's Avatar
Tim:
I installed Hooker headers with a Pypes exhaust kit (like yours) and the collectors did not exit straight back. The RH header seemed a bit off when compared to the LH side. I spoke with a customer service rep at Holley about this and after seeing the pics, they agreed to send me another set of headers which were exactly the same issues as the first set. While I was waiting on the replacement headers from Holley, I ordered a set of Hedman headers to see if the fit was any better. Unfortunately, the fit was worse; the RH collector was higher than the LH side, the LH side was right up against the starter motor (and I already installed a smaller, gear-drive starter) and they had the same ****-eyed RH alignment.
I felt the Hookers had better construction (thicker head flanges and thicker primary tubing). So I sent the Hedmans back to Summit and decided to rework the Hookers. The Hookers were too tight to the LH lower control arm so I reworked 2 of the primary tubes to allow more clearance. I also cut off the flat, 3-bolt collector flanges and welded on a ball & socket type flange which allowed a more flexible connection to the Pypes straight pipes. I chose not to install the "X" or "H" pipe so it was easier to assemble each side independent of the other. Here's some pics of my struggles.
Rodney
These are the Hooker 3901 headers; the passenger side looks crooked.
Hooker 3901 again: passenger side is closer to the transmission.
These are the Hedman headers; the passenger side collector is about 1-1/2" higher than the LH side.
Hedman headers had the same ****-eyed collector alignment and the RH side was longer than the LH side.
cdrod is offline
Old March 19th, 2022, 06:17 AM
  #267
Phoenix8990's Avatar
Maybe reverse that section so you have some straight right after the headers.
Steve
Phoenix8990 is offline
Old March 19th, 2022, 08:54 PM
  #268
tkcutlass's Avatar
Some goodies showed up today.
Got the driveshaft properly seated.
Got two of three torque converter bolts in. (need to pick up a 1 1/8 socket to turn the crank.)
Put a couple of sensors in from the Dakota gauges. (any sealant recommended?)
Old March 19th, 2022, 09:20 PM
  #269
I know it was a lot of money, but you will not be dissapointed in the VHX dash.
You might want to consider any other readings you want to keep track of now. You and add additional modules later, but posistioning and wiring all of the modues now (trans temp, fuel pressure, etc) will make it so much easier. Also might want to consider the retained accessory delay. Keeps accessories runnig until the door is open, and will automatically turn the lights on at night.
Old March 24th, 2022, 01:34 PM
  #270
tkcutlass's Avatar
More goodies gonna need to paint the dash black but got a fair deal on these parts
Old April 17th, 2022, 06:57 PM
  #271
tkcutlass's Avatar
Finally got the trans tube sorted out and the basic plumbing is done.
Put the sensors and water valve on, getting very close to where I can put the body on.
waiting on the proper pcv hose.
Old April 19th, 2022, 10:45 AM
  #272
akspeedy's Avatar
Looking Good.
akspeedy is offline
Old April 20th, 2022, 08:05 PM
  #273
tkcutlass's Avatar
Sorting out the shifter.
Old April 23rd, 2022, 07:37 PM
  #274
tkcutlass's Avatar
Finished a few things and got the body one the frame.
Need to verify alignment and get the body bolts in.
I picked up some cage nuts for the front cowls not sure what the best way to get them in properly they are supposed to be welded in.
Old April 24th, 2022, 09:54 PM
  #275
tkcutlass's Avatar
Had to adjust it slightly but got all the body bolts in (except the front two which I may weld new cage nuts in or take the easy way out and just use a hex nut seeing how it's accessible.
Got the shifter cleaned up and hit it with boeshield.
Removed the hoists and door bars.
Old April 25th, 2022, 05:23 AM
  #276
Rodney
cdrod's Avatar
Tim:
The factory used a square nut with front body bolt (at the torque boxes). The bolt goes up through the frame and the nut is inside the torque box. Without the front fenders and the plastic fender liners, It's pretty easy to hold the nut with your finger and tighten the bolt from below with a ratchet.
Rodney
cdrod is offline
Old April 25th, 2022, 08:21 AM
  #277
tkcutlass's Avatar
Originally Posted by cdrod
Tim:
Rodney
Thanks, Rodney, that should simplify things
Old April 27th, 2022, 09:20 PM
  #278
tkcutlass's Avatar
Got the other two body bolts in.
Got the radiator support aligned to the body, hopefully, the body is aligned properly.
Couldn't resist temporarily hanging a fender.
Old April 27th, 2022, 11:19 PM
  #279
Trophyblue442's Avatar
Looking good! It’s a great feeling seeing it come together!
Trophyblue442 is offline
Old April 28th, 2022, 06:37 AM
  #280
Rodney
cdrod's Avatar
Tim:
Looking good! You've come a long way with this car. I admire your determination (and your pace); you have accomplished much in 2 years! Just remember, when you start hanging the sheetmetal, start with the doors and work your way forward. Get the rear gap the way you want it and then move on to the fenders setting the gap at the leading edge of the doors then align the hood to the fenders. Also, make sure the car is on level ground. I found this out the hard way and still fighting an overly large door-quarter gap on the RH side of my car. I can't figure out way the right rear of my car is 1/4" higher than the left rear.
Rodney
cdrod is offline
Quick Reply: 70 cutlass supreme convertible my first frame off
